Author Topic: Converting electric doors to manual  (Read 17285 times)
Offline djvsantana
« on: March 02, 2011, 10:30:46 am »
Ok guys im new on this site and am looking for some help. I just recently bought a 1980 silverado short bed that needs a bit of work. One of the first things I want to do is replace the doors. It has manual doors on it at the moment and I want to leave them manual, but my father has some electric doors at his shop that are already shaved and in great condition that I could use. Like I said they are electric but I want to change them to manual. What do i need to do to make this happen? Any help or info would really be appreciated.
Offline jaredts
Re: Converting electric doors to manual
« Reply #1 on: March 02, 2011, 11:20:04 am »
Electric locks require nothing extra.  Use manual door panels and remove the actuator, if you want manual.  From power windows to manual requires the manual window regulator, crank handle+clip, and manual window door panels.  I bought manual doors and converted them to electric and it was a piece of cake, just read up on the regulator removal as it can be dangerous.
Offline djvsantana
« Reply #2 on: March 02, 2011, 12:15:26 pm »
So what if i decided to leave the shaved doors electric. What kind of wiring would I have to do then since I have manual doors now?
« Reply #3 on: March 02, 2011, 12:19:00 pm »
Just remove all the guts from each and swap them.  You need the harness from the power to make it work.
Offline djvsantana
« Reply #4 on: March 02, 2011, 02:39:15 pm »
is there anything on this forum that explains how to wire them up?
« Reply #5 on: March 07, 2011, 07:02:05 pm »
The wiring diagram section.  The harness is seperate, so you can get it from a donor.
