Author Topic: Need help identifying truck.  (Read 11719 times)
Offline zslates
« on: March 03, 2011, 08:42:23 pm »
I'm trying to id my 77 truck.  I was thinking it was a heavy half but not sure now. I'm also thinking that it doesn't have smog equip because it's over 6000. Thought?
- k10
- 6200 gvwr
- no f44 option
- 6 leafs in rear
- 4th digit in vin is 1
- no smog equipment and it doesn't look as though it ever had any.
- it's a ca truck out of freemont.
- vin Ckl147z126356
- Gawr front/rear 3520
Re: Need help identifying truck.
« Reply #1 on: March 03, 2011, 09:05:42 pm »
If the 4th digit would have been a 4, it would have been a heavy half but being a 1 it is just considered a 1/2 ton
http://www.73-87chevytrucks.com/VIN.htm
Offline zslates
« Reply #2 on: March 03, 2011, 09:21:01 pm »
door plare
Offline txchainsawgogi
« Reply #3 on: March 03, 2011, 09:42:20 pm »
i just learned i have a heavy half  8)
Offline slammed79
  • Thou shalt not drive stock
« Reply #4 on: March 03, 2011, 09:46:20 pm »
Its supposed to have cats on it, maybe an egr. It should at the very least have a charcoal cannister on it. Is Paradise in Tehema county? I really can't remember if they are a no smog county or not.
Praise the lowered
« Reply #5 on: March 03, 2011, 09:50:32 pm »
If it is the gvwr rating you may have been high enough for no cats.  Does the fuel gauge mention unleaded fuel only?  I had a 1978 F150 that didn't have cats.
Offline zslates
« Reply #6 on: March 03, 2011, 11:04:21 pm »
I don't believe I've seen the unleaded fuel only sticker, but will have to check
« Reply #7 on: March 05, 2011, 09:32:46 am »
     c=chevy, k=4x4, L=350 v8 4 barrel, 1=1/2 ton, 4=cab +pickup box, 7= 1977, z= assembly plant (Fort Wayne, Indiana/ Fremont, California/ or Spring Hill, Tennessee, unfortually it doestn't tell you which one), 126356= serial number.  If it was made in the Fremont plant for California it should have had smog epuipment on it, more than likely it was made at one of the other plants and brought to California.
« Reply #8 on: March 05, 2011, 09:50:16 am »
In my link Z is Fremont for the plant.
Offline zslates
« Reply #9 on: March 05, 2011, 11:39:26 am »
There's no unleaded fuel only sign on the fuel gauge, it just says fuel.
Since its 6200 GVWR it must have not had the smog equipment (even thought its a CA truck) and it's not a Big 10 (F44) option.... so maybe all k10's around this year we're over 6000 GVWR.
Anyone else have a k10 CA truck around this year that's under 6000 gvwr?
Zack
Offline 1979C20
  • Kyle Taulton.
« Reply #10 on: March 20, 2011, 07:30:39 pm »
My 79 c20 is 11,000 gcw from cali and it came LOADED wiyh smog equipment.
