Author Topic: tpi help  (Read 4960 times)
Offline autofreak
tpi help
« on: March 06, 2011, 10:30:44 am »
hey guys i have an 87 swb 4x4 with a 350 out of a 71 chevelle, and a 4spd. I would like to go to a tpi system  my question is what years should I be looking for, should I look for the corvette or camaro style. and how difficult is this swap as i know nothing about fuel injection. I know that I will need the computer and wiring, intake, and fuel pump. Is there any thing else i need to watch out for? Any help would be greatly appreciated. thanks
Re: tpi help
« Reply #1 on: March 07, 2011, 06:39:22 pm »
You need the early style that will bolt up to the old block, but I suggest getting the later upper section without the 9th injector and use the later model ECM.  It is going to be easier to just buy a complete setup that is refurb'd in my opinion.  Been there, done that...
Offline topp
Re: tpi help
« Reply #2 on: March 07, 2011, 09:48:51 pm »
And you'll need a Fuelie Tank with baffles...
'90 Suburban TBI 350
Offline autofreak
Re: tpi help
« Reply #3 on: March 07, 2011, 11:41:42 pm »
thanks guys for the info. i found a good deal for a setup off a 87 iroc. computer wiring the whole shmeer. im hoping it works
Re: tpi help
« Reply #4 on: March 09, 2011, 08:05:13 pm »
Intake will need to be adapted to go on "normal" heads.
Offline autofreak
Re: tpi help
« Reply #5 on: March 09, 2011, 10:42:32 pm »
are the center bolt heads different. what would I need to do to make it fit
