Author Topic: sound deadener  (Read 4031 times)
Offline PromiseKeeper
sound deadener
« on: March 07, 2011, 12:50:55 pm »
Hey Guys...
I scored some heavy rubber mud flaps from semi's. Was thinking of putting some on the floorboards of my truck as sounds deadener before I put it back together. Think it would work?
Scott
Offline Edahall
Re: sound deadener
« Reply #1 on: March 07, 2011, 10:04:09 pm »
Yes it would help some but you need to cover the whole floor to have the most effect.  In fact, there is some stuff that's called MLVB Mass Loaded Vinyl Barrier that's used for sound control that pretty much does the same.
Also, if you want a low cost sound deadener, buy some cheap old paint and mix it up with sand and apply a very thick coat to your floor boards.
« Last Edit: March 07, 2011, 10:07:02 pm by Edahall »
1990 ¾ ton 4x4 Chevy Suburban
-Gear Vendors Overdrive
-Upgraded Holset HX-35 turbo
-NP205 iron transfer case
-3.73 gears
-2" Lift
