Author Topic: Head lights dont work  (Read 5610 times)
Offline BULLDOG
« on: March 10, 2011, 02:10:20 pm »
The headlights dont work on my 83.
Where is the headlight relay and is there anything else I should look at to make the headlights work?
The head light harness looks pretty good no splices and the wiring doesnt look dry rotted .
Black 1983 K20 and sm 465
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
Re: Head lights dont work
« Reply #1 on: March 10, 2011, 02:47:51 pm »
it could be the switch itself.  To remove it, there is a button you have to depress by reaching up under your dash on the side of the switch--push the button in and the knob stem comes out from the front.  Then remove the switch and replace, or just remove and test by jumping the terminals with a stripped wire.  Unless your '83 has the steering column light switch, i don't know when they switched (pardon the pun) over to the steering column light switch.
Offline BULLDOG
« Reply #2 on: March 10, 2011, 06:50:02 pm »
It has the pull out style on the dash switch.
If it is not the switch where is the headlight relay?
« Reply #3 on: March 10, 2011, 07:45:10 pm »
Could be the high / low beam switch. Have you powered up the bulbs?
Offline BULLDOG
« Reply #4 on: March 10, 2011, 08:58:13 pm »
I got the headlights to work my clean up of the alt and starter wiring most of fixed the headlights.
Offline topp
« Reply #5 on: March 10, 2011, 10:24:53 pm »
Just to let you know, there is no Relay in the Stock Headlight system.
'90 Suburban TBI 350
Offline BULLDOG
« Reply #6 on: March 11, 2011, 07:28:14 am »
No relay,so that explans why I couldnt find one then
Offline topp
« Reply #7 on: March 11, 2011, 07:40:14 am »
There is a few people, myself included, that added relays to give full voltage to the headlights.
Offline BULLDOG
« Reply #8 on: March 11, 2011, 08:15:51 am »
Did you all use one of the relay headlight kits that the venders sale?
« Reply #9 on: March 14, 2011, 02:52:58 pm »
yes. I made a post about it.
Offline topp
« Reply #10 on: March 14, 2011, 09:01:25 pm »
I made my own, and used 3 relays, to allow Low, High and Low and High to be on....
