Author Topic: electric fans  (Read 6219 times)
Offline 76k104x4
electric fans
« on: March 13, 2011, 10:30:57 pm »
well i went to Upullit auto and got some dual electric fans off of a 02 caddalac deville and put them on my k10 along with a new 4 core radiator ill try to get some pics up soon
Offline 1980c10
Re: electric fans
« Reply #1 on: March 13, 2011, 10:59:56 pm »
please do.
Offline 1979C20
  • Kyle Taulton.
Re: electric fans
« Reply #2 on: June 22, 2011, 04:00:44 am »
Pictures please?
Offline HAULIN IT
Re: electric fans
« Reply #3 on: June 24, 2011, 06:21:51 pm »
I used a '99 Seville fan set-up. It's very similar to the Deville one. It works GREAT! You check out some pictures here: http://forum.73-87chevytrucks.com/smforum/index.php?topic=12211.msg95075#msg95075
Offline 1980c10
Re: electric fans
« Reply #4 on: June 24, 2011, 10:56:31 pm »
Nice set up haulin it.
I finally got mine in. I installed it between the radiator and grille.
It is a hayden brand run with an inline fuse, temp sensor and an adjustable thermostat. very simple wiring kit
funny thing is people ask me how well it cools with out a fan.
Re: electric fans
« Reply #5 on: June 24, 2011, 11:11:10 pm »
Looks good, does 1 fan do a good job? I have dual 12in fans and they work fine so far.
whats the 180* bent piece for?
Offline 1980c10
Re: electric fans
« Reply #6 on: June 25, 2011, 01:18:50 am »
My fan is 16", never had a problem cooling I can pretty much put my hand on the radiator at any given point. If anything it is probably overkill. There are 4 differant radiator options for these trucks I have the largest size available in stock form so that probably helps as well. I have seen much smaller fans set up on some jeeps and other hot rods. A big fairly open grille also helps these trucks cool.  The 180 piece is for opening the hood it will eventually have a trunk popper attached in the future hooked up with remote keyless door locks, it is just one of those things that I will complete eventually.
Here is a better look at the fan as you can see it is an 8 blade mounted tight up against the radiator and blows air through very nicely.
