Author Topic: Worn parts on the front end?  (Read 6644 times)
Offline BULLDOG
« on: March 15, 2011, 03:48:58 pm »
So how do you tell what parts are worn out on the front end of a 83 k20?
Right now the truck wonnderes a little and there is a slight shimmy.
How can I tell if its the ball joints or the tie rod ends or the steering box or maybe bushigs?
Black 1983 K20 and sm 465
Re: Worn parts on the front end?
« Reply #1 on: March 15, 2011, 04:20:45 pm »
      First do what they call a dry test.  Have someone turn the steering wheel back and forth with the truck off and inspect all the front suspension parts, then you should be able to see if something is excessively loose or not.
Offline 1980c10
« Reply #2 on: March 15, 2011, 05:28:32 pm »
the parts you will be you pitman arm(attached to steering box), idler arm(the other frame rail about same position as pitman), inner and outer tie rod end both sides. with the truck off the ground, grab the front tire right side and left side, move back and forth, listen for a clunk and feel for play. if you have some check the previous mentioned parts,
Use the same test except grab tire tire top and bottom, if this fails check the wheel bearing.
this is a good test anytime your truck is lifted off the ground, only takes a few seconds.
but also do as bake '74 says in your situation
Offline BULLDOG
« Reply #3 on: March 15, 2011, 05:46:22 pm »
So what kind of ball joint and tie rod ends do you all use and bushings and who makes a good steering box?
Offline 1980c10
« Reply #4 on: March 15, 2011, 06:09:04 pm »
I use moog.
Don't you have a solid front axle?
Offline BULLDOG
« Reply #5 on: March 15, 2011, 07:03:44 pm »
Yep solid axil
Offline 76k104x4
« Reply #6 on: March 15, 2011, 10:08:21 pm »
also after i replaced my ball joints and wheel bearings on my k10 it still wandered my steering stabilizer was shot i changed it and all was right with the world it helped the most in my opinion
