Members Rides
My 83' frame off resto with 5.3
4
5
Topic: My 83' frame off resto with 5.3 (Read 50574 times)
daytonagp4
Re: My 83' frame off resto with 5.3
Reply #15 on:
April 01, 2011, 08:13:39 am »
just ordered my brake lines, fuel line/pump, new fuel tank and sending unit, and some other odds and ends!!! looks like i'll be busy next couple weeks!!
84chevysilverado
Reply #16 on:
April 01, 2011, 02:16:46 pm »
looks sweeeeeeeeeet
40sand20s
Reply #17 on:
April 07, 2011, 09:44:04 am »
Thats gonna be my next build project after my 78 2wd and both my blazers get done. Is a mid 70s 4wd shortbed on 40s and 20s or 22s. Show truck/ dd. Im in the process of building my 95 4wd 4 door s10 blazer up right now, im gonna put a 6.0 408 stroker in it and straight axle swap it on 35s and 20s.
Nice truck. I hope all my stuff turns out as good as yours. Ill be subscribing to your thread as i may need some ideas on my 78 as im putting a 6.0 408 stroker into it as well
daytonagp4
Reply #18 on:
April 09, 2011, 02:02:56 am »
Thanks guys!! It's been a LONG process but it's turning out to be worth it.\
Got most every thing outside cab wired up, looks good the way my buddy did the wiring. I was able to hide everything very well computer sits behind the dash. you can only see like 3 wires. I still need to wire up the truck power and some other things under hood but should be done this weekend with that. Brakes are mostly done, ordered my rear rubber line...when that's in it's done. gotta pop the water pump back off and get the new pully pressed in too. Anyway off to bed ....enjoy!
team39763
Reply #19 on:
April 09, 2011, 01:10:12 pm »
I like how you painted it. That motor looks good in there.
Gilby959798
Reply #20 on:
April 09, 2011, 09:40:30 pm »
looking good...
'86 K10-Budget build
'98 Cobra-Toy
'95 Mark VIII-Daily Driver also a toy
'97 Mountaineer- 5.0 AWD Her Car
'00 F-250 7.3L PSD 4x4 Winter toy
bake74
Reply #21 on:
April 09, 2011, 09:47:29 pm »
How hard was it to stick that 6.0 in there ? I am interested on how it turns out.
74 k10, 77k10 Tom
daytonagp4
Reply #22 on:
April 10, 2011, 01:31:02 pm »
It's a 5.3 and it wasn't hard so far....do a search and there will be plenty that show up showing step by step how to do it and all the parts you will need to get it done. Wiring is moderatly hard but if you take your time it can be done. Just do your research before you jump right it.
daytonagp4
Reply #23 on:
April 17, 2011, 09:06:05 pm »
Well after countless hours of work and thousands of dollars 4years later i hear the truck turn over!!!!! Not running yet, don't have the PS fbody mani yet and i still need to finish my fuel system. But i'd say another couple hrs worth of work and this puppy is ganna run!!!!
jdhall144
Reply #24 on:
April 27, 2011, 07:32:08 pm »
Sweet truck!!
captain carnage
Reply #25 on:
April 29, 2011, 11:54:26 pm »
Awesome truck, and an insane amount of work
daschlag
Reply #26 on:
April 30, 2011, 09:53:55 am »
Nice truck!
1977 K20 4x4 400 TH350
big bear
Reply #27 on:
April 30, 2011, 10:18:00 am »
great project for sure
daytonagp4
Reply #28 on:
May 01, 2011, 06:02:20 pm »
IT'S ALIVE!!!! aLIVE I SAY!!!... Got it running today....holds an idle pretty good considering the exhaust isn't built and the o2's aren't hooked up. But it runs!!!!!
big bear
Reply #29 on:
May 01, 2011, 07:39:06 pm »
congrats man !!!! thats awesome
4
5
Members Rides
