Author Topic: stupid people and waterpumps  (Read 4671 times)
Offline txchainsawgogi
« on: March 22, 2011, 07:45:52 pm »
It seems the previous owner thought it was a good idea to jb weld the weep hole when the pump went out. Absolute idiot. 30$ and an hour later and I had replaced my old water pump. Cleaned some engine gunk and repainted the brackets.
Also I don't know if you recall me complaining about not having a timing marker...but I found it...bent up against the timing chain cover and covered in a few mm of dirt and grease.
Offline Grim 82
Re: stupid people and waterpumps
« Reply #1 on: March 22, 2011, 08:35:38 pm »
lol, glad you found it  :D
« Reply #2 on: March 22, 2011, 10:15:12 pm »
yeah but i dont get it...because its really not visible unless you have the water pump off... which... should always be on the block right? haha.
Offline 1979C20
  • Kyle Taulton.
« Reply #3 on: March 23, 2011, 01:37:37 am »
You have to look straight down between the water pump and the front of the block. And, the timing tab should be at a 90 coming off the timing cover.
Offline roger97338
« Reply #4 on: March 23, 2011, 07:37:00 am »
I wonder if the previous owner bent the timing tab out of his way, so that he could lay underneath the truck and plug the water pump's weep hole with epoxy. I bet he even spent the extra money and used water-proof epoxy. In fact, I'm going to bet that he had no idea what a weep hole is, and he couldn't get the water pump bolts any tighter... lord knows he kept trying though...and that water pump he put on it five years ago "had a lifetime warranty, so it's NEVER gonna go bad!" (Don't forget, some people actually think that!) So, after running a bunch of stop-leak through the cooling system, this was his last, best idea to fix that leak. Then he sold the truck, because it was "giving him too many problems".
