Author Topic: any tips for changing my trans filter/gasket/rear seal?  (Read 9065 times)
Offline txchainsawgogi
« on: March 22, 2011, 08:22:07 pm »
i've got all the parts ready to go...i just need to wait for my day off!
Re: any tips for changing my trans filter/gasket/rear seal?
« Reply #1 on: March 22, 2011, 09:07:56 pm »
What I do is use some thread and tie the gasket onto the pan in a couple spots to help hold it in place. Others use some sort of gasket maker and tac it in place
Offline roger97338
« Reply #2 on: March 23, 2011, 07:40:32 am »
Wear safety goggles! There isn't a good way to prevent a large sploosh of trans fluid once that pan comes loose. Have plenty of hand cleaner available, too.
« Reply #3 on: March 23, 2011, 07:43:58 am »
If you loosen the bolts on one side and remove them on the other it will let the fluid poor out that side
Offline roger97338
« Reply #4 on: March 23, 2011, 07:49:43 am »
Yes it does. Not as nicely as a drain plug though.
« Reply #5 on: March 23, 2011, 07:52:27 am »
Yeah you might wana look for one lol.
« Reply #6 on: March 23, 2011, 09:51:19 am »
What about for the rear seal? I've never removed a drive shaft!
« Reply #7 on: March 23, 2011, 11:07:28 am »
Remove the clamps at the rear that hold the u joint in place. You might have to pry the shaft free but once it does tape around the u joint so the two caps wont fall off. Slide the shaft free from the transmission you will lose fluid if the trans is full so wait till you empty it. You can use a screwdriver or the seal tool to pry the old seal out. Then use a 2x4 or something that will have contact all around the seal cause it has to go in flush.  then tap it in place with a hammer with the 2x4 in between the hammer and seal so you also don't damage the seal.
« Reply #8 on: March 23, 2011, 01:02:00 pm »
X2 I dont know why pans dont come with drain plugs.
« Reply #9 on: March 23, 2011, 07:17:06 pm »
The seal came with a metal shim....what do I do with that?
Offline Dr_Snooz
« Reply #10 on: March 23, 2011, 08:05:22 pm »
Throw the factory pan away as soon as you get it off. Then clean up the mess it makes. Then replace it with a pan that has a drain plug. The best way to seat a new seal is to use the old seal flipped over. It fits perfectly and you can beat on it with impunity. Coat the new seal with a little oil before putting it on.
« Reply #11 on: March 24, 2011, 12:06:30 am »
X2, they have some that hold 2-3 more qts too. Summit has one that is thick aluminum. I have one and the flange doesnt warp if its too tight.
Huh??
Offline roger97338
« Reply #12 on: March 24, 2011, 01:34:11 am »
I've had my eye on those trans pans in the Summit catalog! Those things look great; They're more rigid than the flimsy factory piece, they have cooling fins or hollow tubes, increased fluid capacity, drain plugs, some have a fitting for a temp gauge....now if they were within the budget of the woefully unemployed (me), that would be most excellent!
« Reply #13 on: March 24, 2011, 11:00:31 am »
When you can get one, get one. i love it. Mine has the cooling fins. I figured the tubes could get clogged up with mud. Mine doesnt have a temp fitting, but Im going to put one in the cooler line anyways. Its easy to add one in the pan though, its thick.
« Reply #14 on: March 24, 2011, 11:54:12 am »
What's the fuid capacity of a th350 2wd in a 78 long bed?
