Author Topic: My tach upgrade... in the works  (Read 13493 times)
Offline modular93fox
« on: March 22, 2011, 10:15:05 pm »
Been wanting to get a new dash pad and with that means I need to remove the tach thats mounted through the dash pad.. so I found a tach out of a Mecury Cougar with the 4.6 v8.... mint cluster that I took apart to get the tach out... this is what I ended up with...
Before I took the needle off of the tach, I used some equipment at work that can send a specified voltage at a specififed frequency so I was able to map out various RPM points. After it was mounted, I set the needle back to the OE position.
All I have left to do is scope out the LS tach output and get it to match up with the Mercury tach... and then install in the truck :)
clint
1987 5.3 4l60e Silverado - daily driver with A/C,P/W,P/L,TILT, HID projectors & 13.8" Rear Disc Brakes
A poor man buy's it twice
Re: My tach upgrade... in the works
« Reply #1 on: March 22, 2011, 11:01:16 pm »
     Is the blank spot in the bottom for a fuel gauge ?
« Reply #2 on: March 23, 2011, 12:19:38 pm »
its probably for warning lights
Offline 1979C20
  • Kyle Taulton.
« Reply #3 on: March 23, 2011, 12:31:56 pm »
Its probably like on our trucks with the Brake and Seatbelt indicators maybe?
« Reply #4 on: March 23, 2011, 08:09:45 pm »
yeah, there are some factory 87 warning lights there... seat belt and something else. I drilled out the rivets on the fuel gauge to remove the gauge part, and likewise to a spare oil psi gauge... just found some tiny screws, and installed the fuel gauge to that. I rubbed off the oil symbol and re installed the needle. Once i get the tach operational, i will put the new fuel gauge where the clock would go.
clint
« Reply #5 on: March 26, 2011, 09:45:56 pm »
tuned the tach output signal to 4, which is 6 cylinder mode due to the way the tach is currently wired. Read pretty accuratly, but has a dead zone like spot betweeen 1100-1300... no biggie as it reads almost exactly what HPtuners says after that. Good enough for now.
