Author Topic: Drive Shaft Length  (Read 6509 times)
Offline williebm3
Drive Shaft Length
« on: March 29, 2011, 01:30:17 pm »
Are the driveshafts for a 1/2 ton and 3/4 ton with a 700R4 and 208 the same length? Was thinking about this and wondering if one from a 1/2 ton would be long enough to make up for a 4" lift on a 3/4 ton? any input would help. I know that I would have to use a different u-joint.
Offline mats1985gmc
Re: Drive Shaft Length
« Reply #1 on: March 29, 2011, 04:52:36 pm »
I dont know it this helps but I swapped my stock th350 for a 700r4 and used the same shaft.
Offline williebm3
« Reply #2 on: March 29, 2011, 07:51:07 pm »
Truck has a TH 350 and 203 in it now. Taking 700R4 and 208 out of another truck and putting it in. I do have the drive shafts from the donor truck but the drive shaft was only in the 208 maybe 1 1/4" so with the lift I was wondering about different lengths of shafts.
« Reply #3 on: March 29, 2011, 07:51:34 pm »
     I could be wrong, but I believe they are the same length, If I'm wrong someone will chime in.
« Reply #4 on: March 29, 2011, 07:53:19 pm »
     You posted while I was, easiest way is to measure the length you need and see if yours will work.
Offline williebm3
« Reply #5 on: April 10, 2011, 08:01:51 am »
Thanks, but was trying to start looking while I was in part getting phase. I was just wondering as I know the corp 10 bolt would be shorter on the pinion than on the 14 bolt. Thought I could find one of them and then just put a conversion u-joint in it.
« Reply #6 on: April 10, 2011, 11:28:29 am »
I want to say it will work. My bud has a k5 10 bolt and swapped it out for a d40 and full floater that I gave him. Now it did have a4" lift before the swap I'm sure the drive shaft was stock with only 4" lift
Offline williebm3
« Reply #7 on: April 30, 2011, 08:27:11 am »
Drive shaft is 52 3/4" center of joint to center of joint. Would like to get one about 54 to 54 1/2", and was wondering if anyone would mind measuring their 1/2 ton with a 700 and 208 I would appreciate it.
Thanks for any input.
Offline williebm3
« Reply #8 on: April 30, 2011, 10:05:13 am »
That is for a 8' bed 3/4 ton.
