Author Topic: Can I trailer cars with my 80 chevy k10?  (Read 18703 times)
Offline Cheyenne
« on: April 04, 2011, 08:42:50 pm »
I want to haul cars with my chevy k10 4x4 truck it's in good condition southern truck i been a car guy my whole life. Question is could I trailer safely one car maybe even a older classic car on a trailer?
Re: Can I trailer cars with my 80 chevy k10?
« Reply #1 on: April 04, 2011, 08:45:41 pm »
ive towed boats and car trailers with my truck and never had any problems. The key is maintenance and prevention. If you are going to tow a lot, expect fuel economy to eat your wallet. I would upgrade to a larger diff cover and get a external transmission cooler.
« Reply #2 on: April 04, 2011, 09:03:21 pm »
I would strongly suggest only using a trailer with trailer brakes.  You will need a class III hitch and a brake controller for electric brakes.  What is your engine/trans/rear end ratio combo?  If you have highway gears in it you will overheat your transmission without an external cooler if you have a lot of hills to navigate.  If you have an overdrive transmission don't tow in overdrive.  I am sure others will chime...
Offline Cheyenne
« Reply #3 on: April 04, 2011, 09:11:58 pm »
What's up guy from Hebron my family from Hammond ind generations I live in nwi to brother.. Anyways I know little about trucks I know it's all stock from Alabama even got air cond.. That being said it's got a 350 the rest I don't know I always been a car person these old Chevys I grew up in a 78 Cheyenne was great so I got a 80 but it's a k10 cheyenne I flip cars time time need a good hauler... Want it to work not just sit and go store in.. The brakes and hitch I was aware of as we towed campers as I was a kid... Towing a car on a trailer I know lil rear ends and ratios I know lil.. It's not a 4 speed manual it's a automatic no granny gear manual on this truck..
« Reply #4 on: April 04, 2011, 09:27:38 pm »
If it is stock more than likely it has a TH350.  Does it have a sticker inside the glove box door?  It should tell you what the rear end ratio is.  I have towed with 1/2 Ton pickups and you really have to watch them.  Hammond Indiana was my stomping grounds as I just lived over the state line in Dolton where I grew up.
Offline Cheyenne
« Reply #5 on: April 04, 2011, 09:49:04 pm »
Yeah it has numbers in the glove I put them up sounds like a half ton won't do it huh? Dolton I know good I'm from Chicago heights but my mom was from Hammond.. My grandfather had a car lot from 70s to the 90s 169th and Columbia he was a bit shady with people big man former trucker WWII vet got over on people.. He was good to me though ha
« Reply #6 on: April 04, 2011, 09:54:35 pm »
I didn't say it wouldn't do it you just have to be careful with stopping and the handling of the truck if the trailer isn't loaded just right it get to swaying and it will get away from you if you are not careful.  Been there done that...
« Reply #7 on: April 04, 2011, 09:56:29 pm »
     Use a load lever hitch also, as long as car and trailer does not out weigh your truck by 3 you will be fine.
« Reply #8 on: April 05, 2011, 04:09:02 pm »
Ive trailered my 86 c10 with my buddy's 88 full-size blazer with 4" lift and 38s. Granted we made this trailer just for towing 73-87s with mud tires and she had electric  brakes so I knew this trailer from hitch to ramp never did we have a problem with her. I wouldn't think of doing it with out a brake controller
Offline Cheyenne
« Reply #9 on: April 06, 2011, 01:45:00 am »
Thanks everyone for the advice I like to learn as much as I can, you guys know a lot more than me so I'm all ears.. Here the numbers in glove there a lot diffrent than reading my cowl tag on my 64 impala ss that's for sure. Here the numbers. Vin CKL14AJ134258. Cargo rating 604 Lb. Dimensions "A"  70 in. Dimension"B" 0 in.
Offline Cheyenne
« Reply #10 on: April 07, 2011, 01:07:29 am »
Can anyone tell me what these numbers mean in the glove thanks..
« Reply #11 on: April 07, 2011, 06:19:10 am »
http://www.73-87chevytrucks.com/VIN.htm is how to decipher the numbers.  Yours in confusing because the 6th letter should be a number which tells the year...
« Reply #12 on: April 07, 2011, 08:45:25 am »
http://www.chuckschevytruckpages.com/7980VIN.html  using this source your VIN checks out.  A= 1980
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
« Reply #13 on: April 07, 2011, 08:48:47 am »
This I agree 100%  it will make towing enjoyable instead of a white knuckle experience.
Offline Cheyenne
« Reply #14 on: April 07, 2011, 11:55:30 am »
Thanks for the hitch advice I rather not have any white knuckle driving, if that was the case I would not even attempt it figured I check with you guys on that. It's a 80 chevy, k10, 350, 4x4, long bed, Janesville plant.. The numbers in the glove what do those mean, there nothing like my old cars with a cowl tag..
