Author Topic: purple and yellow and purple wire  (Read 9396 times)
Offline 76k104x4
« on: April 12, 2011, 10:24:03 pm »
I have a purple and yellow and purple wire going into a connector but not hooked up to anything under my dash on my 76 k10 with manual trans anybody got an idea what these wires go to?
Offline Grim 82
Re: purple and yellow and purple wire
« Reply #1 on: April 12, 2011, 10:32:57 pm »
IIRC it's for the neutral safety/park safety switch.
Offline 76k104x4
« Reply #2 on: April 12, 2011, 10:48:47 pm »
were is it supposed to hook to or where is the switch at it is not hooked up to anything right now
Offline Grim 82
« Reply #3 on: April 12, 2011, 11:04:26 pm »
Look for the plastic switch that slides open and closed when you push the clutch pedal.
Offline 76k104x4
« Reply #4 on: April 12, 2011, 11:07:43 pm »
thanks man ill check it out tomorow but i dont think i have a switch it might be missing and my clutch is linkage type not hydraulic if that makes a difference but ill let you know tomorow
« Reply #5 on: April 12, 2011, 11:28:47 pm »
If its disconnected then its been by passed. The truck wouldn't start with it unplugged, and an open circuit.
Offline 76k104x4
« Reply #6 on: April 13, 2011, 11:17:24 am »
sorry guys the wires are purple and white and purple not purple yellow and purple it was dark last night and i was looking at it with a flashlight i do not see a switch on the clutch pedal and the connector does not have a jumper wire in so how else could it be bypassed thanks
Offline Grim 82
« Reply #7 on: April 13, 2011, 11:49:31 am »
Can you post a pic of the wires and the connector? We need more info, as far as if anything else doesn't work right, for example if your high beams don't work then those wires could be for your floor dimmer, if your reverse lights don't work then it's for that, etc., but a pic would be best.
Does the truck start without the clutch pressed now? You should have that switch on the pedal with the yellow and purple wire. On an automatic the same wires go to the park safety switch at the base of the steering column. Has the column been swapped?
« Last Edit: April 13, 2011, 11:51:05 am by Grim 82 »
Offline 76k104x4
« Reply #8 on: April 13, 2011, 01:25:57 pm »
Yes the truck will start in gear without the clutch pressed or in neutral without pressing the clutch
The column hasn't been swapped as far as I know but my dash does have the place wher park reverse neutral and drive would be on an automatic trans vehicle can I add pics with my iPhone if so I will just let me know how to thanks
Offline 1979C20
  • Kyle Taulton.
« Reply #9 on: April 13, 2011, 01:42:15 pm »
With your iphone, Open a reply and to the left of the post button there is a link that says "Additional Options". Click that and at the bottom of the options that open up it says attach and there is a browse button. Click browse and find your pictures. Select the picture you want and it will upload it when you post. It will not show in the post preview. You can attach up to 4 by pressing the "more attachments" button to the right of the browse button. I do it all the time from my Samsung Vibrant, Android phone. Should work from the iphone, But I have never tried it from one.
Offline 1980c10
« Reply #10 on: April 18, 2011, 10:51:46 pm »
The pedal assembly on the left is the hydraulic set up, on the right is the mechanical linkage you can see the switches installed.
If you dont have the switch installed you can pick them up from your local auto parts store.
However, if it is unplugged the circuit should be open(the engine should not turn over without the clutch pushed in) and you'll have to find where it was bypassed and undo it.
