Author Topic: 1984 K30 receiver hitch  (Read 19117 times)
Offline corndiesel
« on: April 14, 2011, 05:16:43 pm »
I know this isn't the best picture but would you guys be comfortable pulling a 7000 pound car trailer with the bumper/hitch setup that I have.
Offline corndiesel
Re: 1984 K30 receiver hitch
« Reply #1 on: April 14, 2011, 05:18:40 pm »
Here's is a picture from farther away. I'll try to get a picture of how it is connected underneath. Thanks.
Offline Da67goatman
  • Burban
« Reply #2 on: April 14, 2011, 06:18:17 pm »
Is it a single axle trailer?
<Pitcrew>
Offline corndiesel
« Reply #3 on: April 14, 2011, 06:39:16 pm »
No, dual axle with brakes on trailer and controller in truck.
« Reply #4 on: April 14, 2011, 06:48:08 pm »
With a home made set up it is hard to say, sorry...
Offline Da67goatman
  • Burban
« Reply #5 on: April 14, 2011, 06:55:49 pm »
How doe that bumper attach to the frame? 4 bolts, 6 bolts, welded?
<Pitcrew>
Offline corndiesel
« Reply #6 on: April 14, 2011, 07:03:11 pm »
It's bolted but how many bolts I am not sure. I'll have to go get a picture of it in the morning for better analysis.
« Reply #7 on: April 14, 2011, 07:24:24 pm »
     First question I would ask is, Did you weld the bumper/hitch ?  2nd question, are you a good welder ?  If you are comfortable with the welds and it is bolted in at least 6 spots ( class 4 hitch specs ), 7000 lbs should be no problem.  3rd question, what wall thickness is the metal ?
     If you know nothing about the welder or welds, find someone who welds and have them look at it, they should be able to tell you.
     If you can do none of the above, hook up the trailer and block the wheels, put some strain on the hitch and see if it stretches or cracks, more than likely the person who built it, built it to tow and probably went overboard and made it stout enough.
« Reply #8 on: April 14, 2011, 07:40:16 pm »
most hitches can only carry 5000 unless you have a weight distribution kit, which will allow up to 10k. Without a sticker to tell you the hitch specs, I wouldnt. Just think of the liability if it were to break and if someone who was injured were to find out...
Offline Grim 82
« Reply #9 on: April 14, 2011, 07:44:17 pm »
As you said, the picture isn't the best, but from first glance the reciever tube does not appear to be very thick, it doesn't have the reinforcement collar on the outside, and who knows about the quality of the hitch mounting design or the welds. I don't see any provisions for safety chains either. I personally wouldn't do it.
Offline corndiesel
« Reply #10 on: April 14, 2011, 08:00:30 pm »
Nice catch. There currently is not any means to attach safety chains. I traded in my 2003 1/2 ton silverado for a car so my old truck has come in charge of pulling the trailer around. It definitely has the power to pull just needs an upgrade in the hitch.  Does anyone know of any good companies that sell receivers for a 1 ton truck that have used these receivers. Thanks.
Offline fitz
« Reply #11 on: April 14, 2011, 08:12:01 pm »
Whenever I need a hitch I go to uhaul. It's. About $150. For a class 3 hitch for your truck.
« Reply #12 on: April 14, 2011, 08:23:39 pm »
You should be able to find a Class 4 hitch. look for a dealer for either valley, draw tite, or hidden hitch.
Offline Da67goatman
  • Burban
« Reply #13 on: April 14, 2011, 08:30:41 pm »
My dad just bought a class 5 hitch from Curt for his 1 ton Van.  Paid $200 and it come with wiring t-harness and ball mount hitch.
<Pitcrew>
Offline SMiller
« Reply #14 on: April 14, 2011, 08:50:04 pm »
http://www.curthitchdepot.com/trailer-hitches-multi-fit-receiver-hitches-c-82214_82216/multi-fit-receiver-hitch-p-16598
Biggest\baddest hitch 15,000lbs tow rating and good price, bolts right on. There are HUNDREDS of places that sell it, find the best price with free shipping and go for it! Dont just use a U-hail hitch, not very heavy duty.
