Author Topic: Brakes....  (Read 5482 times)
Offline zslates
Brakes....
« on: April 22, 2011, 07:55:56 pm »
I replaced my master cylinder and my brake booster. Bench Bled the master.  When i half way depress the peddle its super easy and i can see brake fluid (cap is off) squirting like a fountain out of the largest reservoir.  After that it gets harder, but only will travel about 1-2 inches
This doesn't seem right.  Any thoughts?
Offline 1980c10
Re: Brakes....
« Reply #1 on: April 22, 2011, 07:59:09 pm »
Bleed your brakes; you have air in the lines somewhere.
Re: Brakes....
« Reply #2 on: April 23, 2011, 07:38:36 am »
Start with the fartest away from the master first and bleed all four wheels brakes.
Offline topp
Re: Brakes....
« Reply #3 on: April 23, 2011, 11:25:02 am »
Yup, Bleed 'em.
After you replace the Master you have air in the lines where the brake lines connect to the master.  You have to bleed it all the way through the lines....
'90 Suburban TBI 350
Offline zslates
Re: Brakes....
« Reply #4 on: April 23, 2011, 12:00:29 pm »
Yup Brakes are much better now.  Thx all!
