Author Topic: TH350 C problems  (Read 2818 times)
Offline racetowin
TH350 C problems
« on: May 01, 2011, 03:32:05 pm »
86 c-10 2wd p/u. Trans will not downshift to 1st gear when at a full stop (starts off in 2nd) you can pull it into 1st and it will work. Will shift from 1st to 2nd fine but will not shift into 3rd. Its like having a stall when you let off of the gas. It is still in 2nd and will not shift into high. This happened all at once no warning at all. Ck vac to mod valve and ck for fluid in mod line and there is none. Fluid level is good.
Re: TH350 C problems
« Reply #1 on: May 01, 2011, 03:35:03 pm »
     Did you check the detent cable for proper adjustments ?  I am sure more people will chime in when they see this.
Offline racetowin
« Reply #2 on: May 01, 2011, 03:46:10 pm »
truck has been a daily driver for awhile and no changes have been made . Do they require adjustment at random times ?
