Author Topic: 75 c10 cab swap  (Read 5171 times)
Offline otakie
  • 1975 Chevy C10 STEPSIDE
75 c10 cab swap
« on: May 08, 2011, 07:10:38 pm »
i have a 1975 chevy c10 and i am trying to swap an 85 cab on to it.  What mechanical issues will I run into?  Is there any way I can keep my round headlights/grill?  Also will the door guts from my 75 with vent windows fit in doors on an 85 with solid piece window?
Any help would be great...
Re: 75 c10 cab swap
« Reply #1 on: May 08, 2011, 11:29:15 pm »
85s have vent windows too, unless someone spent a chunk of change and installed after market one piece units. The guts will swap but you might need to drill a few holes. Use the 75 nose and you can stick with round headlights. You will need to swap in the wiper stubs and wiper transmission arms from the 75 into the 85 cab. If you leave the 85 stubs in the hood will clean them off the first time you close it. One of the holes for the wiper stubs lines up on each side. The other two for each side needs to be drilled as they are off about half of the hole. Use the wire harness from the 85 cab as long as it is a two head light set up not a 4 light. Your 75 probably has a mechanical oil pressure gage unless its got idiot lights. You will need to install after market gages, or put the 85 electrical sending unit in.
 You will need cab mount bushings for a 75. Is the 75 auto or stick? 2 or 4 wheel drive? Is the 85 cab auto or stick? 2 or 4 wheel drive? Answers to these will determin if the center of the floor needs to be cut out and bolt the 75 center in.
Re: 75 c10 cab swap
« Reply #2 on: May 09, 2011, 06:41:00 pm »
     4wd with stick generally have high humps in the middle, while 2wd auto's generally have small humps.  If you have both cabs do a comparision to make sure it will work.
