Author Topic: Filler Tube Diameter  (Read 6752 times)
Offline slammed79
  • Thou shalt not drive stock
« on: May 08, 2011, 08:17:12 pm »
Anybody know the OD of the filler tube on our trucks? I want to order a tube for my pending blazer tank swap, but I haven't ripped into the truck yet to start it.
I'd like to get this swap done before I leave for California. I'm going to swap in a 30 gal tank before I go, and having the extra 10 gallons will mean prolly one less gas stop along the way.
Praise the lowered
Offline ehjorten
Re: Filler Tube Diameter
« Reply #1 on: May 10, 2011, 11:09:32 am »
And help you make it to the next gas station when crossing the Mojave! :D
-Erik-
Offline slammed79
« Reply #2 on: May 11, 2011, 10:10:51 pm »
Indeed!
Praise the lowered
Offline 76StepSd
« Reply #3 on: May 23, 2011, 03:03:00 pm »
I am having trouble looking for a replacement filler tube for my 76 C10 step side. The truck came from Vegas so all of the fuel (rubber) lines were dry rotted plus the truck sat for 3 years. I dropped the tank to replace the sending unit, rubber lines, and clean the tank....the fuel was brown...lol. I measure the neck on the tank for the filler hose and it was approx. 1.375 inches. So I guess it was around 1 3/8 inches.
Offline slammed79
« Reply #4 on: May 24, 2011, 07:36:18 pm »
Disco! Thanks 76Step. Napa sells the rubber filler hose buy the inch, if you don't have one close try car quest.
Praise the lowered
Offline 76StepSd
« Reply #5 on: June 02, 2011, 07:33:12 pm »
No prob slammed79 i still could not find the replacement filler hose that connects to the tank on my truck so i inspected the old one....at first glance i thought it was dry rotted but after looking closely at the surface whatever coating they used when they make the hose was what was flaking so its still in "ok" condition so i reinstalled it....would i like new replacement? yes...but since its been discontinued i have to make due for now.
Offline slammed79
« Reply #6 on: June 03, 2011, 10:55:02 pm »
Trying to find stock replacement stuff will be hard if not impossible. The hose that Napa sells is universal, but if what you've got works then even better.
Praise the lowered
