Author Topic: bumpin  (Read 5860 times)
Offline barneyb1
bumpin
« on: January 13, 2007, 07:22:00 pm »
what does it take to have a sub
what do you need in a head unit to wire the amp
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
Re: bumpin
« Reply #1 on: January 13, 2007, 11:35:00 pm »
Most amps have a subwoofer out (rca plugs)
If not, you can just use regular speaker outputs to sub, it would be best to have another amp for the mid and high.
As far as the head unit, most have rca plugs for pre-amp out. Or, you can split the regular speaker outputs and have on branch go to your amp---if you do it this way, you may not have balance/fader capabilities.
Most amps have volume control to adjust according to your desire.
If your amp is really high, like 500 watts or higher, may wanna get a capacitor so all your alternator amps wont be used up during a really bass-y song--you don't want the music to fade during each beat.
I run an 8 guage wire directly from the battery to amp, with an inline fuse (50amp) really close to the battery, to may 1000 watt puppy. I got 2 12 inch woofers behind the seat---I now have seat massage--not bad for a 79 pickup.
My suburban is very similar, but only has 500 watt amp--she sounds so sweeeet.
SgtDel
aka "Andy"
www.delbridge.net
1979 Big 10 383 stroker
1991 Blu 'Burb 3/4 ton 4x4
