Author Topic: Speedometer/odometer questions?  (Read 3160 times)
Offline Cheyenne
« on: May 12, 2011, 05:50:58 pm »
My 80 k10 the speedometer just kind of wiggle at around 15 mph even I'm driving 60 mph. I realize there a loose cable some where is located on the truck?
The odometer is fully functional that being said yes the miles go up as it should. The odometer is enough to go past 99,000 miles?? I thought the odometer from that era only went to 99,000 miles. Mine reads with a zero first and than 56k miles. I figured I combine the 2 questions I never really had anyone to teach me on these cars and trucks. I'm going to learn from forums and hands on..
Offline 1980c10
Re: Speedometer/odometer questions?
« Reply #1 on: May 12, 2011, 11:17:57 pm »
you have a speedometer cable it connects at the back of your speedometer and to the transmission, this can be removed, inspected and lubed and it may solve your problem. btw the cable can be removed by reaching under the dash-so no need to remove the speedometer itself.
Do you have a pic of your speedometer?
