Author Topic: ignition switch help  (Read 7007 times)
Offline BIG CHEVY
  • FOLLOW ME,,,, ILL TRY IT.
« on: May 12, 2011, 06:21:32 pm »
Ok.......my ignition switch works great. My radio remembers every station and stuff all times.
When i flip my key back nothing happens. I dont have any radio only type acc action. I have the position. And it moves just fine to the position. But must not b hooked up right. Can u guys tell me how the wires should hook up in the ateering column? I know radios good. I know wiring good. But dont know the action at the switch. Help?
Offline ccz145a
Re: ignition switch help
« Reply #1 on: May 12, 2011, 10:10:19 pm »
take your tap from an acc slot at the fuse panel.
Offline BIG CHEVY
« Reply #2 on: May 13, 2011, 07:29:00 am »
Will do. Does anyone have a diagram or layout of the fuse panel? Its a 79 k-10 pickup with 350? I have no book and all worss on fuse box are worn off.
« Reply #3 on: May 13, 2011, 11:10:21 am »
cant remember but i want to say its a blade in the fuse panel. dont have my truck here to test
Offline ccz145a
« Reply #4 on: May 13, 2011, 12:35:52 pm »
You can also use a voltmeter or test light and test slots with ign. turned to acc.
Offline BIG CHEVY
« Reply #5 on: May 13, 2011, 12:55:44 pm »
I got er.........but maybe someone could post the fuse i.d. and i could have it in emergency?
Offline DnStClr
« Reply #6 on: May 13, 2011, 05:00:17 pm »
73-79 fuse box should be the same for every year.
http://www.chuckschevytruckpages.com/77fusebox.html
Don
87 Chevy Silverado
