Author Topic: th400  (Read 4198 times)
Offline 77chevyshortbox
th400
« on: May 17, 2011, 09:15:20 pm »
I've got a th400 with a np208, and a np205 of a th400. I have the adaptor bracket for the th400/205. would of had the tranny to, but was in rough shape so settled for another th400. anyways i wanna bolt the np205 upto the th400 that had the np208, only question i have is do i need to do anything else or is the adaptor enough? had someone say tailshaft needs to be changed due to length issues or spline. not sure any input helps.
Re: th400
« Reply #1 on: May 17, 2011, 09:52:30 pm »
It does come with two shafts since you don’t have both transmissions i don’t think you can tell the difference. The difference between the two is only 1 5/8"
Re: th400
« Reply #2 on: May 17, 2011, 09:53:54 pm »
« Last Edit: May 17, 2011, 09:56:44 pm by Irish_Alley »
Re: th400
« Reply #3 on: May 17, 2011, 10:36:53 pm »
so basically figure out which shaft and spline count i have and if it doesnt match the 205, i should steal the one off the other tranny? hah
Re: th400
« Reply #4 on: May 18, 2011, 10:09:42 am »
the splin count should be the same
Re: th400
« Reply #5 on: May 18, 2011, 11:06:27 am »
beautiful thanks for the info
