Author Topic: power steering whine  (Read 4853 times)
Offline the_legend_1981
« on: May 19, 2011, 05:22:34 pm »
Ok this isnt 73-87 but i have a 94 chevy 1500 with 305. the power steering is whining at an idle and i can hear it in 1st and 2nd. The whine does not increase when turning the wheel. Should I try bleeding it? is there common problems with the tbi?
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
Re: power steering whine
« Reply #1 on: May 19, 2011, 06:41:49 pm »
sounds like the pump is going.  The same sound will happen when the belt tensioner bearings are about to go too, so, be sure it is the pump.
« Reply #2 on: May 19, 2011, 06:57:11 pm »
how much work is it to change the tensioner?
« Reply #3 on: May 19, 2011, 08:15:06 pm »
is there a way to regrease this?
Offline Lt.Del
  • Andy aka:SgtDel
    • www.delbridge.net
« Reply #4 on: May 19, 2011, 08:18:31 pm »
they're usually sealed units.  AFter removing the belt, You'd have to look at it.  I don't know the setup of a 94, but, there should be a pulley with bearings.  There should be a bolt through the middle or the spring bracket that is held by 2 or 3 bolts..you'd have to look at it.   Still, it could be your p.s pump.  Be sure prior to replacing things.
« Reply #5 on: May 19, 2011, 08:34:56 pm »
ok. thank you
« Reply #6 on: May 19, 2011, 08:39:46 pm »
doesnt sound like its coming from the power steering side so i'll take the belt off tomorrow and see whats up.
« Reply #7 on: May 20, 2011, 06:07:28 pm »
exactly what it was...thanks again
Offline Lt.Del
  • Andy aka:SgtDel
    • www.delbridge.net
« Reply #8 on: May 20, 2011, 08:11:14 pm »
glad to help.
