Author Topic: TH350 Selector Plate Problems  (Read 2710 times)
Offline 79chevyK10
« on: May 19, 2011, 07:01:40 pm »
I have a 1979 Chevy K10 Scottsdale with a 350/350 setup in it. The trans was rebuilt right before I bought the truck about a year ago. I am having problems with the nut that is tightened against the selector plate right inside the transmission pan. The selcetor is too loose which is causing me to loose park, and low range gears L1 and L2. When I tighten this nut I can put the trans in all of these gears with the lever off the column.  Is there a retaining clip or something that should hold the nut in place to keep it from backing off, since it might not have been reinstalled during the rebuild?
Thanks
1978 Chevy Monza Spyder -- 305ci V8, 4 Speed, Posi Rear
1979 Chevy K10 Scottsdale -- 350ci V8,  TH350, NP208, add-a-leafs, 32x11.5x15s
1991 Toyota Pickup -- Daily Driver
1993 Toyota Pickup -- Custom Built Rock Crawler w/ Exo Cage, Lockers, and Winch
