Author Topic: Timing  (Read 4937 times)
Offline 87 K20
Timing
« on: May 21, 2011, 07:07:44 am »
Hey does anyone have any advice on where to set timing on an 87 350 with fuel injection?  The emission control label is gone.  Any advice would be appreciated.
thanks,
Mike
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
Re: Timing
« Reply #1 on: May 21, 2011, 09:49:45 am »
My 91 5.7, w/ California emissions, said 0 degrees.   However, I like to run it around 6 BTDC
http://forum.73-87chevytrucks.com/smforum/index.php?topic=9232.0
Offline roger97338
Re: Timing
« Reply #2 on: May 21, 2011, 02:12:06 pm »
According to my Haynes manual, the 1987 350 w/ EFI (no distinction made between California and all the rest) is supposed to be set at 0 (zero) degrees Before Top Dead Center, with the engine at an idle.
Offline Da67goatman
  • Burban
Re: Timing
« Reply #3 on: May 21, 2011, 04:35:32 pm »
0 degrees and remember to unplug the electronic advance.
<Pitcrew>
Offline 87 K20
Re: Timing
« Reply #4 on: May 21, 2011, 06:32:06 pm »
is the electronic advance the only thing that needs to be unplugged?  As said before this is fuel injection and the emissions label is MIA.
Offline Lt.Del
  • Andy aka:SgtDel
    • www.delbridge.net
Re: Timing
« Reply #5 on: May 21, 2011, 10:42:01 pm »
that's all.  look at the link I posted--gives location of spark control tan wire by brake booster.  Zero degrees is correct, but, you may be like me and prefer a slight advance, as long as your engine doesn't knock. I think it has more giddyup slightly advanced.
