Author Topic: K10 Suburban - What Differential Oil  (Read 13163 times)
Offline AdrianR
  • Big Blue Beastie - '85 Suburban K10, 6.2 diesel
« on: May 24, 2011, 10:13:18 pm »
O All-Knowing Oracles  ;)
Methinks it is time to change the oil in both diffs on my Burb (see sig).
What's the best weight/type oil to use and how much does each diff take?
thanx
Chevy lover
1985 Suburban K10 Silverado diesel
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
Re: K10 Suburban - What Differential Oil
« Reply #1 on: May 24, 2011, 10:17:55 pm »
i'd use standard gear oil, 80w or thereabouts.  Fill it up til it pours out the plug hole.
Offline topp
« Reply #2 on: May 24, 2011, 10:19:01 pm »
If you have a Limited Slip Diff, you need additive.....
'90 Suburban TBI 350
Offline Grim 82
« Reply #3 on: May 25, 2011, 09:02:24 am »
I read somewhere that you can gain 1 mpg by running synthetic in the diff's, but I can't testify to those results. Plan on about 3 qts or so per diff to fill them.
Offline Skunksmash
« Reply #4 on: May 27, 2011, 05:24:42 pm »
I use royal purple full synthetic. Never had a problem out of it. Haven't really tested the MPG's since I started using it though. However, I never added any additive. And I'm sure my 87 has limited slip, as do most vehicles these days. Which additive should I use?
