4 Wheel Drives
Lift spring question.
Topic: Lift spring question. (Read 26048 times)
1979C20
Kyle Taulton.
May 25, 2011, 07:44:42 pm »
Im getting a 79 blazer next week. I would like to lift it and ive found a few sets of 6 inch rear lift springs on craislist. I asked my dad if I could use rears on the front of my truck and he says the fronts have extra spring(s) for the added weight of the engine. And he said I could use rears on the front with an add a leaf ao they dont sag. Is this correct?
1979C20
Kyle Taulton.
Re: Lift spring question.
May 26, 2011, 03:12:23 pm »
Anybody have any insight or opinions?
K20Wulf
May 26, 2011, 04:42:13 pm »
I'm not going to say no right off the bat, but... If they are 52" springs you may be able to use them, but you will need a kit to relocate the hangers.
http://diy4x.com
has a kit for stock rear 52" springs called "Beyond 52's". You could call them to see if it would work with your springs. Good luck
86 K20 4x4
7" lift, 35's
350/400/208
May 26, 2011, 05:10:12 pm »
i think when i had my 6" front and rear springs side by side the rears where a couple inches longer than the front
1979C20
Kyle Taulton.
May 26, 2011, 06:42:17 pm »
So, if the springs were a bit longer than the front, would that put more arch in them and make the lift higher?
May 26, 2011, 09:07:51 pm »
it might make them sit farther back cause of this would be sitting on the frame rail instead of sitting on the shackels
1979C20
Kyle Taulton.
May 26, 2011, 10:05:45 pm »
Okay. And would that cause any problems?
May 26, 2011, 11:42:50 pm »
wear, maybe a little bit bumpy ride
1979C20
Kyle Taulton.
May 27, 2011, 12:00:57 am »
Wear on what components?
May 27, 2011, 05:29:30 am »
springs&frame rail
May 27, 2011, 05:31:41 am »
i guess you could redrill the shackel hole but be true with it so it won’t mess your alignment up. But it prob will increase you pinion angle a little bit
1979C20
Kyle Taulton.
May 27, 2011, 06:12:38 am »
Okay. Sounds good. Ill have to keep looking. Thats how i found the blazer! I saw a full 4in lift kit.on clist for like 350. So im sure ill.find a decent deal some time.
Reply #12 on:
May 27, 2011, 10:22:40 am »
remember you also need shocks something to drop the steering and brake lines
1979C20
Kyle Taulton.
Reply #13 on:
May 27, 2011, 03:38:09 pm »
Yeah. I was going to try and buy it piece by piece. I found a drop steering arm for 10 bucks, i was planning on replacing the shocks anyway, and ill find the brake lines when the time comes. Thanks for the help irish.
beastie_3
Josh
Reply #14 on:
May 27, 2011, 06:14:56 pm »
you need a raised steering arm, not a dropped one. Or you can get a dropped pitman arm...they also make a Z shaped drag link.
I have a 6 in lift and I have a raised steering arm, dropped pitman arm, and stock drag link. Works perfectly. I also have SS brake lines, dropped T case, and dropped sway bar brackets. All I need to do is lower the rear most parking brake cable brackets, I dont like how the cable has a harsh angle.
Semper Fi
4 Wheel Drives
