Author Topic: Fuel selector valve  (Read 3480 times)
Offline benzesrule
Fuel selector valve
« on: May 26, 2011, 09:09:06 am »
I just installed a new Fuel Selector Valve from autozone, part number FSV1. It won't switch when I push the switch on the dash. Its also new from autozone. Well I called the wells(the manufacturer) and they said that I would have to install a new switch(Sw48). Has anyone else had to do this? I have power down to the switch but it doesn't switch( atleast I can't hear it).
Offline benzesrule
Re: Fuel selector valve
« Reply #1 on: May 26, 2011, 09:59:27 am »
Well to make along story short. I didn't need to replace the switch. I removed the seal off of the plug at the valve and plugged it in and it works. I put the seal back on and pushed the plug on as far as i could and it still works!!! So much for calling the manufacturer!!!
« Reply #2 on: May 26, 2011, 02:16:58 pm »
glad you found the problem.
Offline benzesrule
« Reply #3 on: May 26, 2011, 08:48:00 pm »
Thanks!!! Me too!!!!
