Author Topic: 87-95 383 roller (push rods size  (Read 3710 times)
Offline 305chevy c-10
« on: May 26, 2011, 09:25:55 pm »
has anyone built a 383 with vortec heads ......ifso what length push rods did u use ....stock or ?..............my cam is 268 ad dur 215 /490 lift custom grind ..................i know i need hardened rods for the guide plates ..5/16 ..........also using 1.5 3/8 roller rockers
Heartbeat of America yesterday's cheverolet
18T5C10
Offline TexasRed
Re: 87-95 383 roller (push rods size
« Reply #1 on: May 26, 2011, 09:52:33 pm »
depending on the milling of heads and block, you'll prolly need to check with a pushrod length checker.
I'm running a flat tappet cam with a slightly decked block and vortecs that are milled to a TRUE 64cc, and the checker told me to use stock pushrods, which I did.
