Author Topic: Hood Stuck Closed  (Read 3379 times)
Offline drtbikkid
Hood Stuck Closed
« on: May 27, 2011, 09:13:10 am »
my 78 K10 doesn't have an inside latch and the hood spring (singular) is garbage. i was doing some wheeling and must have torqued the body because the hood wont open. it has never been easy, had to us a big screw drive and a hammer to get it open, and a buddy sitting on the kink in the hood above the drivers side wheel to get it closed. now i think the lever up front is bent up so far fromt he hammering it wont release. I'm gonna do hood pins if i can just get it open. is there ANY way to get around the lever thats bent? I'm starting to think last resorts. any help would help.
__________________________________________
Tire Design Engineer: Toyo Tire North America
1978 K10: 8" lift, Granny 4 speed. 84 Model 305.
"When the only tool you have is a hammer... everything looks like a nail."
Re: Hood Stuck Closed
« Reply #1 on: May 27, 2011, 10:26:51 am »
wow you go by your quote now dont ya lol.
« Reply #2 on: June 27, 2011, 04:31:35 pm »
You should be able to gain access from behind the grille?  Is the outside latch broken, or the spring broken?
