Author Topic: TH350: no reverse, no drive?  (Read 21882 times)
Offline kmcbride74
Re: TH350: no reverse, no drive?
« Reply #15 on: May 27, 2011, 05:56:42 pm »
Yup fellas, handling that now.  I think there is just not enough fluid in it.  Should be case closed later tonight.  Done spiking wrenches for the moment, beer:30. :)
Offline kmcbride74
« Reply #16 on: May 28, 2011, 09:37:50 am »
BTW, does the top connection on the radiator go to the top connection on the trans and the bottom to the bottom?
« Reply #17 on: May 28, 2011, 03:00:42 pm »
Look at the pic in this link
http://www.bmtrans.ca/FAQ's.htm
Offline kmcbride74
« Reply #18 on: May 28, 2011, 04:44:41 pm »
I think both of my cooler lines go right into the back of the radiator.  I believe that is how it was hooked up when I pulled it apart.  Does this sound incorrect?  The picture would seem to indicate one of them would go to the cooler on the front clip...
« Reply #19 on: May 28, 2011, 06:59:32 pm »
thats for a remote cooler. in your case they go into the rad
Offline kmcbride74
« Reply #20 on: June 06, 2011, 09:48:37 pm »
Connected my auxillary cooler per the diagram in the link above, filled up tranny, all good now!  Thanks for the posts!
