Author Topic: Removing Lower A Arms  (Read 4039 times)
Offline TxFiddler
« on: May 28, 2011, 12:22:25 am »
I read about this on here.  Took a couple pics when  I put the drop spindles on.
Take a piece of 3/8 tread stock and basically put a nut on it under the top of the spindle and tighten.  The lower ball joint will pop out pretty easy.
I put a vice grip on the end of the stock and assisted in the turning.
This is really simple to do.
80 C10 2wd / 427 BigBlock / 700R4 / 3:42 Eaton Posi LSD / 770 cfm Holley Street Avenger / Doug's Headers / MSD ProBillet Distributor / Champion 3 row Radiator
