Interior & Equipment
Radio memory wiring info...
Topic: Radio memory wiring info... (Read 26485 times)
bowdown916
May 30, 2011, 03:08:29 am »
I been trying to find the memory wire cuz everytime I turn off th truck the radio gets back to default, it wont safe the radio stations or settings... I think its the yellow wire.. but on the harness there's no yellow wire... there's too many splicers on the harness that maybe last owner change the wiring color... where in the truck the memory wire or acc suppost to be in?
Sent from my DROIDX using Tapatalk
Re: Radio memory wiring info...
May 30, 2011, 04:30:31 am »
where in the truck or on your radio?
May 30, 2011, 04:37:26 am »
if its the radio it prob the orange or yellow one
1979C20
Kyle Taulton.
May 30, 2011, 05:07:12 am »
For the memory wire, just plug it in to the power side of an open, non ignition controlled spot in the fuse panel.
May 30, 2011, 08:26:03 am »
now i see what the question was lol "my bad"
bowdown916
Re: Re: Radio memory wiring info...
May 30, 2011, 09:54:23 am »
Like where it says acc or something like wod on the fuse box.. right now there's a wire plug in where it says ign to the power for the harness and last night I try all other open ones and still wont work.. the truck has aftermarket stereo ..I remember that always on the aftermarket harness its the blue wire but not sure now.
zieg85
May 30, 2011, 11:24:25 am »
Blue wire is usually the power antenna on aftermarket radio. Usually the + for the memory is red. You can splice it into the orange wire going to the cigarette lighter and be done with it.
bowdown916
May 30, 2011, 11:33:34 am »
I found a open space on the fuse box with power.so that should work to right? The other wire in the fuse box that goes in the harness its connected to the ign side..
bowdown916
May 30, 2011, 04:58:11 pm »
Ok.so radio its working now.. but now I have a different problem.. its the cigg. Lighter some how wired to the light right under the cigg lighter n the light on the head liner back by the window?
1979C20
Kyle Taulton.
May 30, 2011, 05:14:15 pm »
Look for the "dome" fuse. Its blown.
bowdown916
May 31, 2011, 08:39:19 am »
All fuses are good..
Grim 82
May 31, 2011, 11:00:13 am »
I would use a test light at the fuse panel and see if you have an open B+ port and run a new FUSED wire to the radio. You will get B+ from the cigarette lighter but I would run it seperately if you can. I had a radio hooked up through the cigarette lighter once and I plugged in a small power inverter and it fried the deck.
1979C20
Kyle Taulton.
May 31, 2011, 11:10:13 am »
Replace the dome fuse. Just because it doesnt look blown doesnt mean it isnt. Just double check ig
bowdown916
May 31, 2011, 08:09:28 pm »
What u mean by b+?
bowdown916
May 31, 2011, 08:10:01 pm »
Ill double check that dome fuse...
