Interior & Equipment
Radio memory wiring info...
Topic: Radio memory wiring info... (Read 26470 times)
slammed79
Thou shalt not drive stock
Re: Radio memory wiring info...
Reply #15 on:
May 31, 2011, 08:20:16 pm »
B+ means Battery Positive.
Praise the lowered
zieg85
Re: Re: Radio memory wiring info...
Reply #16 on:
May 31, 2011, 09:00:28 pm »
Quote from: bowdown916 on May 31, 2011, 08:09:28 pm
What u mean by b+?
Sent from my DROIDX using Tapatalk
B+ is battery positive
PromiseKeeper
Reply #17 on:
May 31, 2011, 09:02:08 pm »
thanks for starting this topic. I put a stock radio in my project and couldn't figure out why it wouldn't hold the settings. I had no clue there was a "memory wire." On my Delco, there were two wires out of the back of the radio apart from the ones that plug in. One was orange and the other was orange with a brown stripe. The orange was the memory wire and the other was a ground. Works like a champ now! Thanks guys!
1980 C-10 2WD short & wide. 305 auto.
Reply #18 on:
June 01, 2011, 12:28:36 am »
battery positive
1979C20
Kyle Taulton.
Reply #19 on:
June 01, 2011, 01:40:45 am »
Pattery bositive.
Buddy
Reply #20 on:
June 01, 2011, 06:55:58 am »
Ok i am a little confused but glad to see that i am not the only one with this problem. I have an aftermarket stereo and am having the same problem. Right now all I did was tab into the fuse panel with a wire for power and everytime i turn the truck off i loose everything. So you guys are saying that all I have to do is take that wire out of there and tap into my cig lighter wire? if thats the case i will try this ASAP because i have been trying to figure this out forever. my next question is now i am not sure if the lighter works....
PromiseKeeper
Reply #21 on:
June 01, 2011, 07:51:12 am »
Buddy,
There are two separate power wires for the stereo. One is hooked up so that the radio is powered only when the ignition or accessories are powered. The other is one that will have power ALL the time so the radio's memory can store the preset stations, the clock keeps time, etc. I knew I had two wires that needed power, but didn't think about needing a constant source until I read this...then MY light came on! LOL
Use a test light to see where there is a tab that is hot all the time. The one I used, said "Power" above it. Vile was referring to splicing into the cigarette lighter wire because it should be closer to the stereo and it's always powered.
bowdown916
Reply #22 on:
June 05, 2011, 06:39:04 pm »
i run a separate wire from the fuse box to that memory wire and its working fine.. im having problems with the cigg. lighter wire right now n its not working,thats why i didnt splice it there...
also since i have a aftermarket stereo ... last owner just cut n bend the metal part where the stereo goes in to fit the aftermarket one,but it seens now that the only thing holding the stereo in place its the plastic front dash which i think that someday it might crack or brake.. anyone have some pics of the installation part of the aftermarket stereo, or know if i could use some type of brackets to hold it inplace...
1979C20
Kyle Taulton.
Reply #23 on:
June 05, 2011, 07:01:23 pm »
http://forum.73-87chevytrucks.com/smforum/index.php?topic=20413.0
cd player install.
The cigarette lighter problem is most likely the fuse or even the wire may be disconnected from the back of it. Use a test light on the orange wire in the back of the cigarette lighter to check for B+. If you dont have b+, replace the fuse, even if it looks good. Then try again.
bowdown916
Reply #24 on:
June 05, 2011, 07:06:09 pm »
the wire was unplug from the back,so i plug it in,it has power but when i try it wont work,but i wont out something else.. when i turn on the inside cab lights on , the cigg. lighter has power,when its off no power... now when its off the under the dash light it stays on... maybe thats why last owner had it unplug lol
PromiseKeeper
Reply #25 on:
June 05, 2011, 08:55:26 pm »
The stock radios had a support bracket that bolted onto the side of the radio case and the other end was bolted to the bottom of the metal dash. I'm sure you could either make one or find one at a junk yard. The only problem I would forsee is having a place on the aftermarket radio to bolt it to. On the stock radios it bolted about midway on the passenger side.
