Author Topic: Gm performance 350SB 'economy' engine  (Read 17695 times)
Offline Elpresidente
« on: May 31, 2011, 04:44:45 pm »
I've been really considering picking one of these up for my daily driver, has anyone bought one/heard of somebody who bought one that could give me a decent review?
http://store.gmperformanceparts.com/store/SelectProd.do?prodId=7665&redir=true&manufacturer=GM&category=Engines&name=350/290%20HP%20Economy%20Performance%20Engine%20&model=%3C!--12499529--%3E
It seems like a wicked deal for what I'd be getting out of it.
'82 Chev Scottsdale
Proud to be Canadian \m/
Offline eventhorizon66
Re: Gm performance 350SB 'economy' engine
« Reply #1 on: May 31, 2011, 05:59:19 pm »
I think that engine is a bad deal.  It's just a 260hp Universal Goodwrench with a cam that's a tad too big for the compression.  The result is 30 more hp at the tippy top of the rev range and a loss of 20-25 ft-lb of useful low-end and mid-range torque.  You can cam a Goodwrench just right and increase both hp and low-end torque.  Also the heads on that engine suck from a performance stand point.
If you are just wanting an affordable crate for a daily driver I would recommend the lower-hp version of that engine.
http://paceperformance.com/i-6484484-10067353-5-7l-ls9-l-lm1-6-1971-1985-gm-cars-trucks-up-to-7200-gvw-with-chevy-350-v8-also-known-as-the-universal-350.html
Or here is an even better stock replacement engine for about the same price as the 290 hp engine:
http://paceperformance.com/i-6484921-12530282-5-7l-l31-r-1996-2000-chevy-gmc-full-size-trucks-1996-2002-g-van-savannahexpress-vans-under-8600-gvw.html
It is the L31 out of the 96-99 CK pickups/SUVS.  It requires a vortec-specific intake, but it offers roller cam, higher compression, and the awesome vortec heads.
Also the following crate is offered exclusively through Pace.  It is the same basic deal as the 290hp GMPP crate, but with a better cam choice and the intake (for square bore carb) is included for about $100 less.  Looks like a better deal than the GMPP 290hp crate to me.
http://paceperformance.com/i-5146377-pac-10067353-pace-pac-350cid-300hp-crate-engine.html
« Last Edit: May 31, 2011, 06:02:24 pm by eventhorizon66 »
'85 C10 SWB 350 700R4 TKO600
Offline Stewart G Griffin
« Reply #2 on: May 31, 2011, 06:12:25 pm »
1) i can't really comment on the 290 horse engine as i've not had one.  But i can say with the 260hp base version i was able to cut a 16.8 quarter mile, which i think is pretty good considering everything is stock---stock exhaust manifolds and 2.56 rear,  AND get the same gas mileage as i'm getting now---i have a 305 with 2bbl now.   So what i'm trying to say is that it is lively without being an excessive gas eater like some small blocks.
2) RE: the L31 roller engine: Hmmm, no core charge either?   Can you find me the v-6 equivalent?
« Reply #3 on: May 31, 2011, 06:34:07 pm »
http://paceperformance.com/i-5135121-12369214-4-3l-l35-w-1997-1999-g-20g30-van-1997-1998-p-van-over-8600-gvw.html
But it's for the high GVW vehicles which may mean the dreaded "low-flow" valve seats.
Offline Grim 82
« Reply #4 on: May 31, 2011, 07:46:20 pm »
I think you could build a much better motor for the same or less money.
Offline roger97338
« Reply #5 on: June 02, 2011, 06:15:37 pm »
I once bought a 300 hp 350 crate engine. I got it home and was in the process of bolting on all the hardware. Well, two of the intake manifold bolts wouldn't tighten, so I pulled everything back off. Those two holes were stripped out. And there were some chunks of metal in the lifter valley! After looking around, those chunks came from the back of several of the intake manifold bolt holes. I sent the engine back and got a refund. After checking around, those crate small blocks are cast in Mexico, and they don't have very good quality control. They seem to have problems with consistently being able to produce good, dependable blocks that don't do things like crumble and crack.
Not to say that they're ALL like that. And, the problem may have been solved by now. But, I thought I'd throw it out there for you anyway.
Offline ToddN
« Reply #6 on: June 02, 2011, 09:06:15 pm »
I agree with Grim
A government big enough to give you everything you need, is a government big enough to take everything you have.
Offline rwhit57
« Reply #7 on: June 03, 2011, 02:53:40 am »
I have the 250hp Goodwrench motor in my truck. I have over 40,000 trouble free miles on it. About a year ago I put an Edelbrock intake, carb, and a good set of headers on it. It runs great, and pulls hard even with my high rear end gears, and I get decent mileage. I'm sure you could build a motor for the same money with more hp, but no warranty and a lot more time involved.
Randy from Okla
Whoever said "Money can't buy happiness" has obviously never seen a speed shop!
« Reply #8 on: June 05, 2011, 09:14:22 am »
What does "low-flow" mean?   i basically want an economical transportation engine that can occasionally haul and tow some weight.  Don't care about performance.  Anywhere i can find the specs?
i noticed that the 6 has a core charge while the 8 doesn't.   i don't get that.
i concur!
« Reply #9 on: June 05, 2011, 03:19:35 pm »
P.S.  Why would an engine (the 260 and 290 horse crates) that is only rated to withstand 350HP max come with 4 bolt mains?
Offline jaredts
« Reply #10 on: June 06, 2011, 10:06:58 am »
My opinion:  they knew they would sell more of them that way.
Offline reload
    • K & K Innovations
« Reply #11 on: June 06, 2011, 12:30:53 pm »
Off subject for one small question, where did you get those headers and who makes them?
Thanks
-Matt
Offline Grim 82
« Reply #12 on: June 06, 2011, 01:14:21 pm »
They look like Hooker comp's.
I agree that the "4 bolt main" is probably a sales pitch, or else they had a whole run of those blocks laying around that they could get for cheap.
Offline rwhit57
« Reply #13 on: June 06, 2011, 05:51:25 pm »
They are Hooker Comps, I Cermatel coated them. They are a great fitting header and work well. I've got 2-1/2" exhaust with Turbo mufflers, pipes are dumped just beyond the differential. People are always asking "what's in it?" It sounds a lot healthier than it is. LOL
« Last Edit: June 06, 2011, 05:55:34 pm by rwhit57 »
Randy from Okla
Offline reload
    • K & K Innovations
« Reply #14 on: June 06, 2011, 10:32:38 pm »
I asked because I recently rebuilt the 350 in my '84 K20, and I used aluminum heads with angled plugs.  They were ebay specials, assembled for less than $500 (don't worry, i wont make that mistake again), and I went through 4 sets of headers before finally finding a set close enough to work with.  I ended up with FlowTech's and had to customize the drivers side.
Thanks for the info!
-Matt
