Author Topic: spraying oil  (Read 20061 times)
Offline 1980c10
Re: spraying oil
« Reply #15 on: June 05, 2011, 10:21:17 pm »
You don't want to use ATF it will eat all your rubber bushings.
you would only use the ATF in small amounts over the most critical areas such as the inside of the very bottom of doors or the inside bottom of fenders etc.
I should have elaborated.
Offline WilliamBos
Re: spraying oil
« Reply #16 on: June 05, 2011, 10:28:29 pm »
Have any of you sprayed the underside of your truck with used motor oil as a rust inhibitor? What kind of sprayer works best? Thanks!
krown rust control or fluid film works great.
Re: spraying oil
« Reply #17 on: June 05, 2011, 10:31:20 pm »
I hope you guys don't mind grime and gook dripping and oozing out everywhere not to mention the smell. Shutz is less than $20 a bottle and for $100 bucks you can do your whole truck thoroughly. Every vehicle I've ever had has been rust free where there was body shutz 30+years old.
Offline WilliamBos
Re: spraying oil
« Reply #18 on: June 05, 2011, 10:43:10 pm »
if it does not drip, then you are not protected.  I do not mind it dropping, as I know it will run onto l the crevices.
Re: spraying oil
« Reply #19 on: June 05, 2011, 11:36:46 pm »
I would use SEM spray on bed liner instead of Rocker Shutz.
Offline jaredts
Re: spraying oil
« Reply #20 on: June 06, 2011, 08:36:27 am »
I'm sure if you reapplied every couple of months oil would work, but that's just nasty--not to mention its not worth the work to reapply.  I would much rather use something similar to undercoating, bedliner, etc.  I just can't imagine doing that on purpose.  I'll spend good money to stop oil leaks so I don't have to deal with that when I'm under there working on something.  I can just see me crawling out from under there with oil in my hair and big black streaks down my clothes--its bad enough without making it worse.  Products made for this stay put--oil washes off.
Re: spraying oil
« Reply #21 on: June 06, 2011, 02:17:06 pm »
If oil didn't work the oldtimers wouldn't have done it, and we wouldn't still be doing it.
 I know a guy that has a 1971 Ford Econoline van that has been oiled religiously every fall since he bought it brand new. It does have a little bit of rust here and there, but when I say a little bit, I mean a little bit. Original paint except the right side front door where some one ran into him in Boston when it was only a few years old.
Re: spraying oil
« Reply #22 on: June 06, 2011, 05:32:47 pm »
     It must be a west coast thing, if a truck out here got inspected and there was evidence of oil sprayed all over the bottom, it would get impounded.
     They make several differn't " under coatings " for vehicles that seal and protect against rust.  But like I said, I am on the west coast and that just isn't done anymore.  The last time I had one done it cost about $200.00 for the whole under coating of a truck at a local dealership.
Re: spraying oil
« Reply #23 on: June 06, 2011, 10:05:54 pm »
I'm with Jaredts on this! I spend lots of time making sure I don't have even a drip under my rigs. My Jeep has almost 400K miles on it with no drips.
Blazin, Body Schutz not Rocker Schutz - I've never used the rocker schutz but the body stuff is awesome for the price and the protection.
Offline PromiseKeeper
Re: spraying oil
« Reply #24 on: June 06, 2011, 10:22:24 pm »
Vile,
what's the difference between rocker shutz and body shutz? (exactly what is a shutz anyways? Sounds similar to irritable bowel syndrome :o) When I made my comment about price, I think I was looking at rocker shutz at like $250 for 6 cans.
Bake, I recently priced getting the truck rustproofed and the estimate was over $400
Re: spraying oil
« Reply #25 on: June 06, 2011, 10:27:47 pm »
I could care less if my rig drips for a few days. as long as its not a leak thats dripping! Once the dust has settle in it doesn't drip anymore.
 As far as getting it on you, bahha, you guys have never worked on Tractors, dump, or log trucks have you? You go under clean, and come out covered from head to toes!
Offline snibook7537
  • Vince Ziolkowski
Re: spraying oil
« Reply #26 on: June 07, 2011, 02:32:34 am »
I have to agree with the guys saying to oil the thing up, my step dads 98 astro van has been oiled every year and it has over 250K on it and the biggest spot of rust on it is the size of a dime on the outside of the front fender, my 87 v3500 looks like it spent it's life in a salt mine and it only has 150K and it had some sort of aftermarket rustproofing stuff applied to it for a while before I got it, the PO told me and I believe him, the stuff just doesn't seem to work as well as good old used motor oil, plus it's free after every oil change. I wouldn't worry about any drips just part it in the street with a bunch of kitty litter and let her sit overnight and then sweep up later.  To me the spray on stuff rustproof that hardens is a joke if there is any hole in the layer it will hold moisture and allow everything underneath it to rust, oil just gets everywhere.
1984 Fiero se pwr windows Holley TBi, cam, 86 5spd
1987 GMC V3500 350 TBi 4spd 205 t-case
Shoulda never sold:
1976 c-10 beater 250-6 4spd no pwr steering, brakes. Recycling truck
