Author Topic: window regulator question  (Read 3602 times)
Offline jdl71
« on: June 07, 2011, 05:56:12 pm »
I've read several posts about the differences between the doors on the 76 down and 77 up doors and know the regulators have a shorter shaft on the older style, but is that the only difference? If I somehow welded a longer shaft on, would they fit in 77 doors or are there other issues? I have 2 complete doors with good regulators from a 75, but would like to use my 77 doors to keep the door panels.
Offline ccz145a
Re: window regulator question
« Reply #1 on: June 08, 2011, 04:51:58 pm »
Guessing from the lack of response that no one knows... I know I don't. Try a test fit. If they bolt up, then weld on your extension.
Offline jdl71
« Reply #2 on: June 08, 2011, 05:05:51 pm »
Someone will know sooner or later. I'm just hoping to get an answer before I tear 2 sets of doors apart only to find it won't work.
« Reply #3 on: June 23, 2011, 12:58:10 pm »
the doors are different in the way the panel mounts.  If you put a 73-76 door panel on a 77-91 door you will have holes exposed.  You can put the wrong regulator in either door though.
