Author Topic: How many lbs of R-134a?  (Read 6374 times)
Offline Harmon
« on: June 09, 2011, 04:50:20 pm »
I have conflicting opinions on this....
I have 86 Chevy c-10 with r4 system converted.  Put new dryer, orifice, and r4 compressor in.  Put cans of r134a in.  Blew semi cold a while, then stopped blowing cold...obvious leak.
I want to put dye in to find where it is leaking....BUT  I do not know how many lbs of r134a is needed in the system.
Anyone have an idea?
Offline KY..Rob
Re: How many lbs of R-134a?
« Reply #1 on: June 09, 2011, 07:34:45 pm »
36 to 40oz should do it.
Offline Skunksmash
« Reply #2 on: June 26, 2011, 05:14:17 pm »
I'm scared to do this cause that little valve can get old and give a false reading. Only way to tell with 100% certainty is to completely drain the system.
Offline topp
« Reply #3 on: June 26, 2011, 11:04:44 pm »
So based on your logic above, you don't trust tire gauges either cause those valves ge told and give a false reading?
Same valve, different seal.  They either open and close or don't...They don't give false pressure....
'90 Suburban TBI 350
