Author Topic: wheel stud install....  (Read 8356 times)
Offline BIG CHEVY
  • FOLLOW ME,,,, ILL TRY IT.
« on: June 09, 2011, 05:02:01 pm »
i bought all new wheel studs and lug nuts today. finally doin it right. i was told u could just tap them in with a hammer. after knockin them out i thought it sounded reasonable. i been hammerin and they get close but they wont seat fully. is there a trick or something i need to know? or do i just keep forcing?
Offline Da67goatman
  • Burban
Re: wheel stud install....
« Reply #1 on: June 09, 2011, 05:08:38 pm »
I put a acorn style lug nut on backwards so it sits flat side towards mounting surface and impact gun em down, pulls them nice and tight.
<Pitcrew>
Offline onelow84
« Reply #2 on: June 09, 2011, 09:46:14 pm »
x2
Offline HAULIN IT
« Reply #3 on: June 09, 2011, 10:04:37 pm »
Put a few drops of oil on the threads first. Put a couple large flat washers down before the nut, they prevent marring while turning...kinda like a bearing. Also don't use the same nut for all of the studs...it can get wore & foul up your new stud. I would suggest not using the nuts to old your wheel on that you used for installing the studs for the same reason. Grab a few extras. Lorne
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
« Reply #4 on: June 10, 2011, 08:03:04 pm »
Only way I ever got them to all seat perfectly without using a nut and washers like haulin it said, was to use a press.   Washers that fit the studs correctly are key for clamping them down.
Offline BIG CHEVY
« Reply #5 on: June 11, 2011, 01:13:56 pm »
Preesed em in at work. Gotta say its nice and tight. Just dont have an impact. And i was scared cause i didnt know how tuff the new studs were.x
Offline jimmyjames
  • 87 R10 Wrangler
« Reply #6 on: August 20, 2011, 06:35:52 am »
I use a socket wrench, impact can cause too much damage.
Offline ehjorten
« Reply #7 on: August 22, 2011, 06:31:16 pm »
Big C-clamp and a deep socket big enough to fit over the stud.
-Erik-
