Author Topic: 3/4 ton wheel sizes  (Read 7664 times)
Offline bill
3/4 ton wheel sizes
« on: October 20, 2002, 07:36:00 pm »
i am in the process of putting 3/4 axles under a 1978 lwb.  my 15" tires are brand new and i would like to be able to stay with the 15" wheel.  will a 15"x12" wheel fit over the rear drums on a '77 3/4 axle?
Offline 79GMC4x4
Re: 3/4 ton wheel sizes
« Reply #1 on: November 28, 2002, 05:40:00 pm »
Why not 15x10's.
'79 GMC shortbed 454 th400 14 bolt FF NP205 Dana 60
Offline 73K20
« Reply #2 on: December 05, 2002, 08:09:00 pm »
The 15" wheel will fit over the rear drums.  The issue that comes to hand when mounting 15" rims on 3/4 ton axles is not the rear axle, but the front.  3/4 ton brake calipers on the front will rub against the wheel, however only a small amount of the caliper needs to be ground off to make the wheel fit.  The best way it to paint the caliper with some cheap primer and the put the wheel on while the paint is wet.  Where ever the paint is messed up is where you need to grind.  Go slow and this should work out fine for you.
1973 K20 - 350/350/205
stranger
  • Guest
15" wheels
« Reply #3 on: December 30, 2002, 09:25:00 pm »
I have also done that (grinding the calipers) ,it does work, but even one small chunk of gravel stone will catch between the rim and caliper,sounds like you are draggin a cat !
