Author Topic: leaking np241  (Read 4430 times)
Offline 76 3+3
leaking np241
« on: June 15, 2011, 01:33:42 pm »
Np 241 leaking atf at rear output. Replaced the rear seal and still leaking. Did some research online and found this to be a common issue. I searched for old forums on leaking 241's and couldn't find anything. Found that a common problem with leaking is a bushing on the rear output shaft of the transfer case. Anyone have experience or info on this or a link? Thanks
Offline Grim 82
Re: leaking np241
« Reply #1 on: June 15, 2011, 03:00:33 pm »
Do you have an excessive amount of yoke sticking out of the t-case? That can cause wobble in the bushing and then the seal will leak, just like my np208 currently does  :-\
Offline 76 3+3
Re: leaking np241
« Reply #2 on: June 16, 2011, 02:24:17 pm »
Grim82- stock height 89 1500 suburban and seems like the yoke goes in far enough. I have read leaks caused by a plugged breather, weep hole in the yoke, bushing and the rear seal. After replacing the rear seal the leak got worse. Hate to take it to a tranny shop if I can figure out where its leaking and address it. Atf drips out and is thrown all over under rig. Frustrating.
