Author Topic: Throttle cable  (Read 4437 times)
Offline derrick79
Throttle cable
« on: June 22, 2011, 01:57:58 am »
With my new edelbrock carb my throttle cable is WAY to long. Is there a way to shorten it up? Also just wanted to ask where a good spot to put my return springs is. The bottom hole that swings up has my detent cable in it. Can I just somehow hook the springs to that stud?
Thanks
Offline 1980c10
Re: Throttle cable
« Reply #1 on: June 22, 2011, 10:05:31 pm »
My throttle cables have always kind of looped, you most likely don't need to shorten it.
Offline jaredts
Re: Throttle cable
« Reply #2 on: June 23, 2011, 05:55:09 am »
I replaced my quadrajet with an Edelbrock 1406.  Used the stock cable and did just as you said with the spring.
Offline kmcbride74
Re: Throttle cable
« Reply #3 on: June 26, 2011, 12:55:07 am »
For the return spring, I bought a braket that mounts using one of the intake manifold bolts.  Suggest looping the cable,  It shouldnt be too long.
Offline bigchevyc30
  • the pig
Re: Throttle cable
« Reply #4 on: June 26, 2011, 10:47:31 am »
my c-30 has the 1406 carb and i didnt have to loop my cable but i have a bracket that came on the truck on the back bolt of the carb to put tension on the cable and have the spring on the engine lift bracket on the front of my motor
1980 c-30 dually R.I.P
1989 R2500 Sub 350/sm465
1984 k10 sub 6.2/700r4
