Author Topic: Just wanted to report back on an old problem fixed...  (Read 5568 times)
Offline Skunksmash
« on: June 27, 2011, 05:30:06 pm »
I started a thread where my truck was idling rough. Tried several times to fix it, never could. Tried Redline fuel system cleaner, and now the truck feels like its not even running when its at idle. Also my valve clatter stopped, so I no longer have to run 89 octane if I don't want valve clatter. Maybe someone can benefit from my hours of research into the best fuel system cleaner. Redline is it. One bottle treats 100 gallons, but its fine to use it on a normal sized fuel tank. Redline contains the most of any brand of the actual cleaning agent. Only other one that would seem to compare is RXP. Had a good experience, so I just thought I'd share in case it can help someone else.
Offline bobcooter
  • 1979 Scottsdale C-20
Re: Just wanted to report back on an old problem fixed...
« Reply #1 on: June 29, 2011, 08:58:56 pm »
That's good to know, Thanks.
Offline kmcbride74
« Reply #2 on: June 30, 2011, 05:08:43 pm »
Good info, along these lines, I had similar issues on a truck a year or so ago and used Lucas.  It seemed to work well.  Not to take away from your experience but as another data point...
Offline Skunksmash
« Reply #3 on: July 02, 2011, 11:44:40 am »
Did you use the oil thickening agent, or do they also have a fuel system cleaner as well? I've heard a lot of people have fixed slipping transmissions with lucas.
Offline kmcbride74
« Reply #4 on: July 08, 2011, 12:50:33 pm »
I used the fuel system cleaner only
« Reply #5 on: July 08, 2011, 11:59:33 pm »
skunk Lucas makes fuel system cleaner, transmission slip fix and power steering fluid. I think I may have seen some more but I cant think what they were maybe a gift pack or something
Offline Skunksmash
« Reply #6 on: September 08, 2011, 04:58:41 am »
The power steering fluid isn't synthetic is it? I'd like to try it on my stang, but that pump absolutely hates synthetic power steering fluid.
« Reply #7 on: September 08, 2011, 09:01:48 am »
i would think, i know it has stop leak in it
