Author Topic: Ignition back feed?  (Read 3468 times)
Offline smfreema
Ignition back feed?
« on: June 29, 2011, 08:36:32 am »
84 Chevy shortbed project. 383 stroker/HEI. No tilt steering column. Everything was working fine until the other day i had it running and went to turn the key off and the motor keeps running. Had to choke it out to kill the motor. Replaced ignition/Key and that didnt change anything. I am getting backfeed to Dist somewhere? The two wire plug on alternator is getting constant power? i unplugged alternator completly and that didnt change anything either. Something has failed somewhere because i didnt have this problem before.I read on other posts maybe the ignition switch under dash? Any ideas on how to trace where i'm getting constant power from? I am still thinking its something switch related in column?? Anyone else had this issue??
Thanks
Re: Ignition back feed?
« Reply #1 on: June 29, 2011, 09:48:16 am »
the ignition switch is connected to the ignition cylinder. so its still in the column sounds like your problem
