Author Topic: has a diesel effect  (Read 4634 times)
Offline bigchevyc30
  • the pig
has a diesel effect
« on: June 29, 2011, 02:09:50 pm »
ok i have a 1980 c-30 with a 366 big block in it sometimes when i shut it off the truck will still keep turning itself over and over like some diesels today it did it for like 30 seconds when i shut it off what could be causing this or has anyone else had this problem
1980 c-30 dually R.I.P
1989 R2500 Sub 350/sm465
1984 k10 sub 6.2/700r4
Offline 1979C20
  • Kyle Taulton.
Re: has a diesel effect
« Reply #1 on: June 29, 2011, 04:08:27 pm »
Really advanced timing would cause that.
Offline biscuit41
« Reply #2 on: June 29, 2011, 04:36:48 pm »
I'd check your idle speed as well...
1985 C10 Longbed
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
« Reply #3 on: June 29, 2011, 05:39:32 pm »
advanced timing--retard timing (after checking).
hot spark plugs--get cooler set.
Vacuum leak--check for leaks.
remedy can be using a higher octane, but, that is just covering the problem up.
Can also turn engine off in Drive, then, once off, switch to park.
Offline bigchevyc30
  • the pig
« Reply #4 on: June 29, 2011, 05:51:31 pm »
i thought shutting the motor off in drive was bad for it and it did this with the old motor also i have heavy duty platinum plugs in the truck also for my spark plugs they are different from what i had in the old motor which still did it to. ive checked and my truck has no vacuum leaks.
Offline topp
« Reply #5 on: June 29, 2011, 06:05:04 pm »
It can also occur from carbon deposits in the heads or on top of the pistons....
'90 Suburban TBI 350
Offline jaredts
« Reply #6 on: June 29, 2011, 08:20:13 pm »
I don't know all the possible reasons, but I've seen it a few times from people turning up the idle speed stop screw to compensate for vacuum leaks.
