Author Topic: Hesitation at low rpms...  (Read 6326 times)
Offline kmcbride74
« on: June 29, 2011, 08:56:53 pm »
All,
BACKGROUND: Wrapping up my 305->350 swap, in fine tuning mode.  Truck runs well for the most part, idles well, nice power from about 1/4 throttle all the way to the floor, have timing set per cam spec., 12 degress btdc, valves adjusted.
SYMPTOM: When taking off from a stop, when I first press the gas, it hesitates for 1-2 seconds.  Immediately after that point it runs strong, no missing, no hesitation.
Would this indicate that I need to retard the timing a hair or advance it?
Or, do you have suspicions of anything else that might be the culprit?
Thanks in advance!
Offline topp
Re: Hesitation at low rpms...
« Reply #1 on: June 29, 2011, 09:43:07 pm »
305 or 350 (no need to mention what it was)?
tbi or carb?
Hesitation off idle is usually fuel/air related...
'90 Suburban TBI 350
Offline kmcbride74
« Reply #2 on: June 30, 2011, 08:53:29 am »
Its a 350 with carb, Edelbrock 1406, brand new, supposedly not needing any adjustment...
« Reply #3 on: June 30, 2011, 09:37:47 am »
Don't assume that it is setup perfect right out of the box.  You will need to preform some kind of adjustment.
Offline jaredts
« Reply #4 on: June 30, 2011, 12:58:47 pm »
What's your idle speed?  You could experiment with the different holes on the accellerator pump to see if that helps.
Offline kmcbride74
« Reply #5 on: June 30, 2011, 05:04:41 pm »
at operating temp right at about 700 rpm...I dont think it's an idle adjustment issue.
Offline topp
« Reply #6 on: July 01, 2011, 11:23:07 am »
Auto or stick?
Auto should be 700-750 in drive, stick about 550-600...
It sounds more like a jet issue....
Offline ohio hab
  • 1984 C-10, 383 SBC
« Reply #7 on: July 02, 2011, 06:34:45 am »
Need to advance the timing , 2 degrees is a good starting point, or needs the accelerator pump adjusted , or bigger squirter. Also carb could be lean. Iam not familar with Edelbrock carb's, I alway's run Holley's, but your symptom's, apply to any carb.
