Author Topic: EASTWOODS rust converter  (Read 5500 times)
Offline Zeked
« on: June 30, 2011, 10:54:27 pm »
Has anyone used this product?   I coated parts of my hitch bracing on my 87 short step, and it looks great.  The stuff says that you have to let it cure for 48 hours, but I am impatient to start painting.
Just wonded if you REALLY have to wait two days.
Thanks
Zeke Duge
Often Wrong......Never in Doubt!
Offline jaredts
Re: EASTWOODS rust converter
« Reply #1 on: July 01, 2011, 05:20:42 am »
I've never used the stuff, but if it says to wait I'd wait.  There's some strong chemical reactions going on and I wouldn't want to bury something under paint that's still kickin'.
« Reply #2 on: July 01, 2011, 08:46:49 am »
Yes you have to wait.  95% of paint failures I investigate are due to folks not following the technical data sheets that come with the coatings.
Offline Zeked
« Reply #3 on: July 01, 2011, 11:43:24 am »
Well the results are so goodlooking that I guess I will believe them.
Thanks, guys ...  I have not had such downto earth advice since my Dad passed.
Regards
Zeke
Offline jsessums89
« Reply #4 on: July 14, 2011, 11:23:08 pm »
rustoleum rust converter stuff from Auto zone works 10x better
Offline jaredts
« Reply #5 on: July 15, 2011, 06:34:22 am »
I've used the rustoleum quite a bit, but how do you know it works?  It goes on like black spray paint.
Offline Zeked
« Reply #6 on: July 15, 2011, 11:42:07 pm »
I have used everything rustoleum makes I think..... and they have good products...  I have Never, ever used anything like eastwoods.    took pitted rusted mild steel and made it ready for paint.   will post pics tomorrow.
Zeke
Offline jsessums89
« Reply #7 on: July 17, 2011, 09:41:44 pm »
yea it works great, usually I grind the rust of the metal then lay on at least two coats of stuff and paint over it, although there have been times were i could not grind the rust off and I put the same rustoleum rust converter and it did great just be sure to put down a good layer
« Last Edit: July 17, 2011, 09:43:44 pm by jsessums89 »
« Reply #8 on: July 18, 2011, 08:51:31 am »
     This is coming in a little late, the technicle answere to your question is yes you need to wait 48 hours, the rust converter uses air to start the oxidizing process so the converter can change the molectular structer of the rust.
     If you cover it with paint to soon it's smoothers it and it can not convert the rust properly.
