Author Topic: my 84 SWB project  (Read 5724 times)
Offline chevymanrob
my 84 SWB project
« on: July 04, 2011, 03:56:54 pm »
currently 350/700/373. future plans may include a hair drier or 2 and there is definately a new stance and alot of cleaning up to do....
like it was the day i bought it
and where i stopped today.
i would like to see some solid 13s out of the truck N/A, and maybe 11s after some "exhaust" work. thats a ways down the road. i want it to be a clean driver with a/c first. then we'll open up the 350 and start tinkering.
ex G-body drag fan. best was 11.86 on a 93 octane SBC street car.
Offline big bear
Re: my 84 SWB project
« Reply #1 on: July 04, 2011, 04:08:37 pm »
truck looks solid man.  love the plans.
Offline chevymanrob
« Reply #2 on: July 10, 2011, 06:12:55 am »
i am SERIOUSLY considering pulling this thing down to a bare frame and going for the total clean and paint. how much of a pain is it to pull the cab?
Offline HAULIN IT
« Reply #3 on: July 10, 2011, 10:16:05 am »
 Your only 4 big bolts, shift linkage, speedo cable & a few wires from doing it once it's stripped of the "regular" bolt-on stuff...That is the easy part.
The biggest obstacle for the average guy is lifting/supporting the cab. You just have to be creative (but SAFE!) & use whatever means you have available. If you have a way to do that, it's a piece of cake from there. Jacking & blocking then letting down the frame (removing the front tires & rolling on bare wheels?) can work well if you have access to a bunch of wooden blocks & some sturdy jackstands. However, now you can't easily work on the bottom of the cab. A forklift, skidloader, backhoe, ect. can be used for lifting.
Something I've done several times is to unbolt & lay the cab back on the frame (blocking it up at the top of the rear window opening so the back panel doesn't get bent)...this way you can clean & paint the front of the frame & bottom of the cab, then put it back up, then do the rear of the frame. This is a great way if you don't really have the means to lift or block the cab or the space to have everything separate & is much safer & easier then a bunch of blocks. Have Fun! Lorne
Offline slammed79
  • Thou shalt not drive stock
« Reply #4 on: July 10, 2011, 02:24:49 pm »
What I did in the past, doin the job solo was jack up the cab enough to get a 4x4 piece of wood under it, I had some 8' pieces around.
I got the cab first onto the 4x4's then used a high lift jack to lift the 4x4's high enough to clear the tires and used jack stands on cinder blocks. I rolled the frame out and then lowered it back down the same way as I lifted it. Took some time, but it did what I wanted it to do.
Praise the lowered
