Author Topic: Optimizing MPG's: Gear ratio/RPM's/for mph  (Read 7047 times)
Offline spacetransient
« on: July 05, 2011, 08:17:25 am »
I want to change out my rear to something more practical and got good responses here but since it is a project and the recommendations were such a jump (3.73/3.42) over my current 2.73 ratio that I thought of a better way to ask the question: What rear end ratio will get me the closest to 1950 rmp's in a '89 military series 6.2 diesel with dual exhaust with a 700r4 transmission at 74 mph? My tires are a little oversized at 235/75/15's but still 15's. (I usually run at 70-74 mph for a 65 mph speed limit) I have an '86 Sierra 1/2 ton.
Thanks!!
"It is no measure of good health to be well adjusted to a profoundly sick society" -J. Krishnamurti ... "They who can give up essential liberty to obtain a little temporary safety, deserve neither liberty nor safety" -B. Franklin
Re: Optimizing MPG's: Gear ratio/RPM's/for mph
« Reply #1 on: July 05, 2011, 11:08:03 am »
3.23 will get you there
« Reply #2 on: July 05, 2011, 06:24:42 pm »
Thanks. They do not seem to have a gear set for that at drivetrain.com but they calculated my target 1950 rmp's with 27.5" Diameter tires (235/75/15) with the 6.2 diesel and the 700r4 tranny comes out to 3.08 almost exactly (1948 rpms). 3.23 would work if I went with taller tires.
Appreciate the feedback.
« Reply #3 on: July 05, 2011, 08:13:45 pm »
for some reason i thought those tires where 28.9 idk lol
Offline Stewart G Griffin
« Reply #4 on: July 10, 2011, 09:05:49 am »
What mpg are you getting with the 2.73?
Offline Edahall
« Reply #5 on: July 10, 2011, 09:04:32 pm »
At 75 mph, 3.08's will give you the best gas mileage with the tires you're using.
1990 ¾ ton 4x4 Chevy Suburban
-Gear Vendors Overdrive
-Upgraded Holset HX-35 turbo
-NP205 iron transfer case
-3.73 gears
-2" Lift
« Reply #6 on: July 10, 2011, 11:07:57 pm »
at 75 yes but its getting up to the 75 that will probably burn what you save
Offline Edahall
« Reply #7 on: July 11, 2011, 08:48:56 am »
Hmmm, that's interesting but that's not what I'm experiencing with my 1982 Suburban with the 6.2L.  I've got 3.08's on the rig and I get excellent fuel economy, around 30 mpg on the freeway.  It does very well around town as well.  The 700r4 has a very low 1st gear so it'll even burn a little rubber if I really stomp on it.
On the other hand, my dad has 3.73's and I can't get any more than 21 mpg driving his rig.
-3.73 gears
-2" Lift
« Reply #8 on: July 12, 2011, 12:14:33 am »
if thats what your getting then i just might be doing a swap lol
Offline Edahall
« Reply #9 on: July 12, 2011, 07:39:01 am »
Regarding gas to diesel swaps, right now, I've got a 1999 4 door Tahoe with the 350 Vortec and I'm getting ready to yank that engine out and put in a 6.2L diesel with 3.08 gears.  The Vortec gets no better than 19 mpg while a 6.2L diesel set up properly will get 30 mpg.
-3.73 gears
-2" Lift
